94 SLS idler pulley bolt ripped from block
Results 1 to 14 of 14
Cadillac Seville / Cadillac Eldorado Forum Discussion, 94 SLS idler pulley bolt ripped from block in Past Cadillac Vehicle Discussion; Idler pulley bearing froze up, and when it did it ripped from block and tore bolt housin so its not ...
    Beau2715 is offline Cadillac Owners Member
    Automobile(s): 1994 SLS
    Jan 2014
    8
    Question94 SLS idler pulley bolt ripped from block
    Idler pulley bearing froze up, and when it did it ripped from block and tore bolt housin so its not a flat suface, about 1/2 is still on block. Can i just possibly bypass idler or is it essential? Thought about rethreading old hole but having trouble find new bolt. Any ideas would be great, I really dont want have take shop and get screwed
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No, you can't bypass the pulley. Better hope there's enough left to Helicoil and bolt a pulley back on to, otherwise, it's new block time.
    Jan 2014
    8
    Re: 94 sls idler pulley bolt ripped from block
    Ok, thank you. Is this engine a aluminum block or cast iron, can old hole possibly be filled with weld and redrilled?
    Sep 2010
    East Boston MA.
    29
    26,325
    Aluminum. It would be pretty much impossible to attempt a repair in the car. It wouldn't be easy even out of the car.
    Jan 2014
    8
    Thats what i was afraid of, thank you for info.
    kaceyseldo's Avatar
    kaceyseldo is offline Cadillac Owners Fanatic
    Automobile(s): 97 eldorado
    Nov 2013
    30
    398
    What you have to understand is aluminums reaction to heat. Its tendency to warp in times of crisis. I would say its not impossible, but you better be damn good at machining.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,191
    Re: 94 SLS idler pulley bolt ripped from block
    With a bit of effort and removal of the tire/wheel and inner fender liner skirt, a good Mom&Pop shop can remove the bolt stub, drill and Helicoil the hole for the same sized bolt as original. It's labor intensive but do-able. A Cadillac dealer will charge you the national debt to do it.
    FWIW, there is a chapter in the GM service manual that is dedicated solely to Northstar bolt thread repairs.
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    Just to throw a number in here, the bolt holding the idler pulley on my DHS engine sheared off (? no idea why...), I drove it to a Cadillac dealer on battery power only and gave them a blank check to fix it - they had to lower the engine to weld a nut on to the stub to get it out. Total cost was about $400... which I thought was reasonable (I had dropped off the car on a Sunday and it was done Monday afternoon.)
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    Quote Originally Posted by naif View Post
    Surprising.... must be a quality dealership...
    Jan 2014
    8
    Hmm, maybe I will call the local dealership and see, thanks for input.
    68
    82,056
    Here's a thought that MIGHT work. Fill the hole with JB Weld. Trowel is smooth and place some tape over it so it doesn't run out til it sets up. Then drill and Helicoil it.
    Jan 2014
    8
    I was considering doing this but i wasnt sure how that stuff really works, i have never used it before
    68
    82,056
    It is great stuff and works well. It does take some time to set up though, so like I said, if it is used to fill a hole in a vertical position, I'd tape it after filling as it will run very, very slowly.
  16. #14
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    And don't forget to spray a good portion of brake cleaner in there to get rid of grease and dirt, the surface has to be really clean or the weld won't "glue". I also have had good experience with it on several occasions, including even coolant leaks because of rotten aluminum.
  17. Remove Advertisements
