Dreaded P 056 Code
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Dreaded P 056 Code in Past Cadillac Vehicle Discussion; Son's 1995 Seville SLS is getting the dreaded P056 Transmission Input Speed Sensor code. Check engine light on, I've reset ...
    eldoradogary is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Eldorado, 2000 STS
    Jun 2012
    61
    134
    Dreaded P 056 Code
    Son's 1995 Seville SLS is getting the dreaded P056 Transmission Input Speed Sensor code. Check engine light on, I've reset the code several times and it comes back. The transmission shifts just fine and smooth thru all gears. Any help appreciated.
    68
    81,887
    Re: Dreaded PO56 Code
    If the DTC keeps coming back it's obviously detecting a failure in the ISS. Unfortunately it's not easy to get to.
    Jun 2012
    61
    134
    Thanks Ranger, well so long as everything seems to be fine as far as shifting and operation we'll see how long she will go before failing, will live with the check engine light.
    68
    81,887
    Re: Dreaded P 056 Code
    It's odd that you are not having any shifting problems.
    Jun 2012
    61
    134
    I know, shifts just as smooth as my '95 Eldorado, maybe smoother.
  8. Remove Advertisements
