2000 STS w/117K 'Severe Misfire' advice needed please!
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS w/117K 'Severe Misfire' advice needed please! in Past Cadillac Vehicle Discussion; Good Morning, Had a check engine light (SES) that had been coming on for a while, but car was running ...
    middieblueSTS's Avatar
    middieblueSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2000 STS
    Jan 2008
    Metro Detroit
    102
    Good Morning,
    Had a check engine light (SES) that had been coming on for a while, but car was running fine, until earlier this week... 2000 STS 117K, never have changed plugs.
    Started getting the flashing SES light and car was idling very rough and not running well, even after it heats up. Ran onboard diagnostics and got misfire code P0300 (misfire), and P0410 (Secondary Air Injection). So my suspicion to what was causing the issue was misfire,since it never ran rough before flashing SES came on. Went to autozone and had them run scan and got P0302 (cylinder #2 misfire), and the P0410 again. I replaced #2 plug (OEM Delco) and boot last night. No luck, still idiling very rough, feels like a cylinder is missing under acceleration, and smells like its running rich when I'm outside the car when its running.
    I'm thinking my next step here will be to buy a new front coil pack (cartridge), install, probably do the other 3 front plugs/boots, and then see what happens. If that fixes things and I'm feeling brave I might try my luck at doing the back plugs too (just because they need to be done, but probably not related to this issue). Or maybe take to a shop--looked like there was a lot going on back there.
    Do you guys think this is a good plan of attack/I'm on the right track? Any advice? Any help is much appreciated!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,850
    Re: 2000 STS w/117K 'Severe Misfire' advice needed please!
    Quote Originally Posted by middieblueSTS View Post
    Good Morning,
    YES -
    YES -
    Any advice?
    coil packs are generally very reliable -
    we usually recommend finding good used units over the big bucks for new -
    either the local junk yard - $25 - or ebay - $75 - new $250+
    the only difference between the front coil pack - and rear coil pack is the color -
    ALL 2000 to 2004 Seville models -
    ALL 2000 to 2002 Eldo models -
    and ALL 2000 to 2003 Deville models - use the same coils -
    here is one for $48 with shipping -
    http://www.ebay.com/itm/CADILLAC-DEV...8695a5&vxp=mtr
    only use ACDelco 41-987 spark plugs -
    there is a rebate of $1.50 each - going on until the end of the month -
    http://www.acdelco.com/pdf/Spark%20P...ate%20form.pdf
    carefully inspect the boots - and springs inside the boots -
    any black lines - or any cracks - replace them -
    fivepointohman is offline Cadillac Owners Member
    Automobile(s): 98 Eldorado ( previously 96 SLS )
    Jul 2013
    36
    44
    You need to change all the plugs and wires not just one.. That will create a fuel nightmare for the ECM and the banks will all be different.. At that mileage they need it anyways..
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,850
    Quote Originally Posted by fivepointohman View Post
    what wires?
    Jan 2008
    Metro Detroit
    102
    Quote Originally Posted by basscatt View Post
    what wires?
    I'm just wanting this car to get me through the winter. If I can avoid doing back plugs w/out issues I probably will.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    You need to read up on the significant mechanical differences in Northstar engines and their control/management systems that went into place for the 2000 model year. Apples and oranges.
    ECM went away in ??? 1997 ??? or before. Even your 1998 Eldorado has a PCM, not an ECM.
    69
    82,382
    You might also check for a leaky FPR.
    Couldn't hurt to clean the TB either.
    Jan 2008
    Metro Detroit
    102
    Just following up. Replaced front coil pack and plugs and it fixed the issue. Thanks for everyones help!!
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    ALL 1998 to 2004 Seville models -
    ALL 1998 to 2002 Eldo models -
    and ALL 1998 to 2003 Deville models - use the same coils -
    I'm pretty sure it changed at 2000. My 1998 Seville uses four individual coil packs mounted on top of the engine near the firewall (two wires from each) rather than the cassettes.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Coil cassettes came along in '00, and lasted until '04, when they changes to 8 individual COP coil packs.
    Feb 2006
    57,127
    Looks like basscatt edited his post on coil years ....................
    98cadillac likes this.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    You mean even '96 year vehicles had PCM, and probably I can go back up to '93.
    I do believe the '04 Seville (the few made) had gone away from the '00-'03 cassette design. I believe that year had individual coils for each plug.
    Nobody changes just 1 sparkplug (unless we are talking about my lawnmower or snow blower).
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    In 04, the seville, xlr, srx, went to the 4 coil, 1 coil module per bank.
  16. Remove Advertisements
