1994 SLS charging problems
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1994 SLS charging problems in Past Cadillac Vehicle Discussion; I just purchased a 1994 Cadillac and there is a small wire coming from alternator spliced then going to pcm/ignition ...
    RedCadiSLS is offline Cadillac Owners Member
    Dec 2013
    7
    I just purchased a 1994 Cadillac and there is a small wire coming from alternator spliced then going to pcm/ignition fuse. It also has a light (test light I'm guessing). Any explantion on why this is done? Help please
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    Re: 1994 SLS charging problems
    Quote Originally Posted by RedCadiSLS View Post
    I have no idea of what it might be -
    HOWEVER - I can tell you it was NOT factory installed -
    Dec 2013
    7
    Hmm its still puzzles me why I'm so lost
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    post some pics of what's there -
    maybe someone here can figure out what it might be for -
    Dec 2013
    7
    Dec 2013
    7
    That's the picture of what I was stating. The red wire you see comes from alternator to the light bulb the there is a wire from the bulb to the PCM/IGNITION fuse. Still puzzled on what this is here for please help
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    I just can't imaging what it might be for -
    is the white wire feeding power to the fuse -
    or is the fuse feeding power to the white wire?
    in other words -
    is the white wire connected to the "hot" side of the fuse -
    or the "circuit" side of the fuse?
    pull that fuse - remove the white wire - put the fuse back in -
    see what - if anything - happens -
    Dec 2013
    7
    Ok I took the fuse out cranked up. But funny thing about the fuse its the right size and everything but it wont stay in the holder its a little loose??
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    the brass contacts - where the wire was jammed in are probably bent slightly -
    pull the fuse out - and with a small flat-blade screwdriver -
    bend the contacts closer together -
    that is a 30 amp fuse -
    that means quite a bit of power is being used on that circuit -
    that fuse must fit tight - and make good contact -
    or you could develop some strange problems on that circuit -
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    I have a good idea what it is. I've installed alternators in equipment that had been equipted with generators and they need to have power to activate them. What you are seeing is an activating circuit for the alternator because for some reason the cars wireing wasn't doing the job.
    Dave
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    ^^^ Double that. In that case the light would go on with ignition on and engine off, and go off once the engine is running, pretty much as the little alternator light many cars have in the dash.
  14. Remove Advertisements
