1998 ETC sunroof just starting to act up
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1998 ETC sunroof just starting to act up in Past Cadillac Vehicle Discussion; Today I went to vent the sunroof and it made a stripping kind of noise up to tilt and also ...
    sportmarty is offline Cadillac Owners Member
    Automobile(s): 1998 Eldorado ETC
    Dec 2013
    13
    Today I went to vent the sunroof and it made a stripping kind of noise up to tilt and also when going back to closed. Also the sunroof will not slide back more than an inch and get stuck sounds like the motor is straining. Hope it might be related to the drivers window switch that gets glitch every so often. 39k on car and everything just works fine on the car. Any ideas, help me out.
    Sent from AutoGuide.com Free App
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Nothing to do with the window switches.
    Is this a factory sunroof?
    When it's closed, does the rubber seal look even with the roof all the way around?
    Dec 2013
    13
    Thanks for you response. It is factory sunroof on this vinyl top car, big too. It seals fine but little rip in the rubber that would leak on rear seats until I put electrical tape to temp seal that area. I now park down hill when possible.
    Sep 2010
    East Boston MA.
    29
    26,325
    Does the seal look even with the steel of the roof?
    Dec 2013
    13
    Yes it does.
    Dec 2013
    13
    Well I can slightly push down on the rear side about maybe 1/8 of a inch.
    Sep 2010
    East Boston MA.
    29
    26,325
    Can you push the glass up and down slightly from the inside? If so, the mounting screws may be loose. There're 2 on each side. Open the sun shade and look in at each side of the track.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,603
    Re: 1998 ETC sunroof just starting to act up
    When you set the sunroof glass height - using the 4 mentioned Torx screws - the proper spec is flush with the roofline on the front edge, rear edge flush to 0.5mm high.
    Those 4 adjustment/retainer screws should be checked for tightness every 6 months, more frequently on a sun belt car.
    Dec 2013
    13
    [QUOTE="Submariner409"]When you set the sunroof glass height - using the 4 mentioned Torx screws - the proper spec is flush with the roofline on the front edge, rear edge flush to 0.5mm high.
    Those 4 adjustment/retainer screws should be checked for tightness every 6 months, more frequently on a sun belt car.[/QUO
    My glass is tight and In alignment. But I do not have four screws but I have three Philips style screws along the font edge.
    Also lately the sunroof closed or vent or tilt position makes a flapping noise, just to throw that in there. The rubber gasket is sealing and seems fine.
    Most concerned about the sunroof mechanically
    Quote Originally Posted by MoistCabbage
    Oops exuse me I'm kinda new to forums and first time using the iPod touch to communicate here. Thanks for your patience.
    Sep 2010
    East Boston MA.
    29
    26,325
    We know you're concerned about the sunroof mechanically. If it's not in alignment, or it's loose, that can cause it to bind and cause your symptoms.
    3 screws along the front? Are you sure it's a factory sunroof? The switch matches the one in the owners manual?
    Dec 2013
    13
    Yes same switch as manual. The sunroof is not loose in any way that I can see. It may be the cold weather but that stripping noise when going up or down in tilt is loud. I dunno, if you have any ideas I'd appreciate it.
    I'll do another inspection in the garage later this afternoon.
    Yes the switch and operating instructions are the same in the manual and my car.
    Dec 2013
    13
    Got a hold of my Cadillac mechanic and says that the motor is located between the visors and that is where the sounds are coming from. Stripping noise and motor fading out noise us right there. this will be first step. Find out in spring I guess. Anyone have that sunroof motor? For sale?
  15. Remove Advertisements
