1998 STS charging/battery problems
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1998 STS charging/battery problems in Past Cadillac Vehicle Discussion; I have a 98 Seville STS current issue is in the charging/battery system Recently the Battery started losing charge (battery ...
    Th3Tank79 is offline Cadillac Owners Member
    Automobile(s): 1998 seville sts
    Oct 2012
    37
    35
    Recently the Battery started losing charge (battery only a few months old) so took it in to get tested
    alternator was bad....had it replaced then it was reading a voltage of 16.5 and that the charging system needed to be serviced
    while the engine on n running the door controls (windows, locks, mirrors and even seat controls) would not work
    while the car was off but key in aux everything works perfect!
    Had the used alternator rebuilt and installed still having exact same issue
    could this be a simple ground issue? or problem with the wiring that'll have to be traced?
    thank you for any assistance
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    You might want to check the regulator wiring at the alternator, they must have a good contact in order to work well. Had the same thing going on when that plug got disconnected accidentally.
    Oct 2012
    37
    35
    Re: 1998 Cadillac Seville STS charging/battery problems
    Ive also read that connected to the positive battery cable is a thermister and adding a resistor to this can potentially solve the problem?
    anyone have any luck with this soluition?
    thank you
    Oct 2012
    37
    35
    Update...I've disconnected the thermister that's connected to the positive battery cable
    This lowered my voltage from 16.5 to between 13.8 - 15.1
    But now it fluctuates between that and my lights slightly flicker
    Is there a way to bypass this or add like a resistor to it?
    Thank you
    Jul 2012
    38
    140
    I'd still check that regulator plug and wires, seems to me something got screwed while changing the alternator...
  8. Remove Advertisements
