Transmission 1994---->2001 - STS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac Seville / Cadillac Eldorado Forum Discussion, Transmission 1994---->2001 - STS in Past Cadillac Vehicle Discussion; does anyone know okay Cadillac 1994 gearbox 2001 model of Cadillac, I know that electricity is very similar but is ...
    Remanderi is offline Cadillac Owners Member
    Dec 2013
    20
    does anyone know okay Cadillac 1994 gearbox 2001 model of Cadillac, I know that electricity is very similar but is mechanically the same? gearboxes can be crossed? Will, or even directly in place?
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: Transmission 1994---->2001 Cadillac Seville STS
    You can probably use up to 99. Externally mounted gear selector switch assembly.
    After 00, the gear selector switch was moved inside into the transmission
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Vin Y or 9 makes a difference. Keeps ur computer happy.
    Dec 2013
    20
    Re: Transmission 1994---->2001 - STS
    my car is Seville STS 300HP and bouth tranmission is the final drive ratio is 3.71:1.,car is made 2000 and another transmission is 1994.brouk
    gearbox smells burnt, slipping badly and did not move at all.I would like to know all right mechanical parts between the 1994 gearbox gear box 2000, if only to exchange the electrical parts
    Aug 2007
    mpls mn
    2,528
    does your 2000 have this shifter module?
    Dec 2013
    20
    no,my car transmission not have this shifter module,same like old model,1994----> i check today 2000 model tranny and 1995 tranny,only difference is transmission wire!core,case,valve sytems is same like 2000 tranny.i think i change 1995 tranny,also i change wire and take valve body,up an down 2000 transmission,i dont know why not working,if you know what else is difference,say me!
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    2000 will not work in a '94 as is.
    You might be able to change it over.
    Yours should have the switch circled in yellow in picture.
    Make sure the diff is the same as mentioned before.
    Dec 2013
    20
    my car is the year model of 2000 and it has a gear box broke, I was thinking to change to the 1995 model of the gearbox with gear ratio is the same 3.71:1, with the only difference that I see is the electricity, the electric wires which comes from the gearbox, my car (2000) on the gearbox is not the yellow circled labeled "switch" it is quite similar to the 1995 gearbox, just the pin to which the wire rope will vaihdekepiltä.luuletteko that the exchange is successful if I change the valve body suits up and down, then will be exchanged in the electrical wiring.
    Feb 2012
    NYC
    49
    1,948
    OHH. I thought you were going the other way.
    Then, no, can't do it, as is.
    2000 has an internal neutral mode switch & 1995 has external.
    I'm guessing there isn't a large selection where you are.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    When you cross reference transmissions they only seem to be compatible for a few years in a row. Sometimes it's changes that you can't see.
    Dec 2013
    20
    i make test drive today,1994 transmission working very good 2001 Cadillac Seville STS.only electric wire must change!
    devilledts is offline Cadillac Owners Member
    Automobile(s): 2002 dts
    Dec 2010
    46
    15
    Will a 2001 sts trans work in a 2002 dts iam looking to replace my trans in my 2002 dts with one from a
    2001 sts.
    Thanks
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    2000 to 2004 and '93 to '99 that's the compatibility chart.
  16. #14
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    ........... and VIN Y transmission to VIN Y transmission, same for VIN 9 swaps.
    SLS, ESC, Base Deville, DHS are VIN Y = 3.11 economy highway final drive. (Concours ????)
    STS, ETC, DTS (the real Deville) are VIN 9 = 3.71 performance final drive.
  17. #15
    Feb 2012
    NYC
    49
    1,948
    Unless you Frankenstein a unit like the OP did.
  18. Remove Advertisements
