97 ETC fuel rail issue....
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 97 ETC fuel rail issue.... in Past Cadillac Vehicle Discussion; Can I fix the hose between cylinder 5 and 7 injectors with super glue and electrical tape? I have called ...
    kaceyseldo's Avatar
    kaceyseldo is offline Cadillac Owners Fanatic
    Automobile(s): 97 eldorado
    Nov 2013
    30
    398
    Can I fix the hose between cylinder 5 and 7 injectors with super glue and electrical tape? I have called 3 different part stores only to find out that "we don't carry that item". Its hard for me to believe they don't, but what am I to do?!?!?!?
    rodnok01's Avatar
    Feb 2012
    NC
    6,674
    Re: 97 etc fuel rail issue....
    You must have the plastic lines that were recalled. Very dangerous to attempt a patch job. Don't mess with it unless you can fix properly or prepare for engine fire. Get a stainless set from a salvage yard.
    Its not carried by autoparts store BTW.
    69
    82,163
    DO NOT attempt a patch. You're literally playing with fire. That fuel rail was recalled by GM. As far as I know, recall do not expire as they are safety related. I could be wrong, but I'd take it to a Cadillac dealer and see if they will honor the recall and replace that rail for free. Otherwise follow rodnok's advice and hit the Men's Mall.
    Markosan likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    YEP - NO patch possible or desired.
    Junkyard, GM dealer recall fulfillment, or maybe one of the online GM parts dealers - www.gmpartsgiant.com , for one. Nalley ?
    Tomorrow, talk to Chris in parts at Rippy Cadillac over there >>>>
    or maybe Luke in parts at Lindsay Cadillac over there >>>
    ........... and both are up in the Vendor Forums
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    Re: 97 ETC fuel rail issue....
    So I have just replaced all lines with rubber fuel hose and hose clamps. Worked perfect for a minimal amount of money.
    rodnok01's Avatar
    Feb 2012
    NC
    6,674
    I hope you used Fuel Inj hose and clamps, not the cheap one's. Still should have found the correct one, not saying it will leak but my monye is on it will.
    Feb 2006
    56,582
    Drive alone and never tell your insurance company. As posted, you are playing with fire.
    NOTHING in what you have done is rated for your engine fuel injection line pressures - 41 to 47 psi, running.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by kaceyseldo
    ...Are you serious?!?!?!
    kaceyseldo's Avatar
    Nov 2013
    30
    398
    Re: 1998 STS Fuel Rail
    I had a similar problem. I replaced mine with rubber fuel hose and hose clamps. I don't trust my baby with any money grubbing dealership!
    Moderator edit: This post plus 3 others moved from earlier thread on the same subject, started by a different member. Now all the problems with THIS fuel rail are in one place.
    Feb 2006
    56,582
    As in your other identical post - You're playing with fire. None of the "rebuild" components you listed are rated for the 41 - 47 psi fuel injection service pressures in your car. Always drive alone and don't tell your insurance company.
    GM made a BIG mistake on the original rails, issued a recall, and now you duplicate the mistake with inferior components.
    Feb 2003
    california
    69
    6,680
    That's great but did you use the proper clamps? Fuel hose clamps do not cut into the hose, most coolant hose type clamps do. With the drier fuel now used, hoses dry out quicker and can leak eventually. If you dont trust the dealership, just buy the metal rails and do it yourself.
    Feb 2003
    california
    69
    6,680
    Just call the dealer and read them your VIN number. Recalls do not expire! If your's falls within the VIN spread of the recall, they will be glad to fix it. Fuel hose clamps are specific to their use. They are designed to not cut into the hose. Some people call them "EURO" clamps. The newer fuels are very dry and WILL cause premature failure of the hose even with proper clamps. I have purchased 2 cars that were totaled because of an underhood fire. I replaced the hoses and clamps,and spark plug wires damaged in the light fire that occurred because there was no metal line repair available. Believe me, the hoses will fail again!
    69
    82,163
    This is the result of an Eldo with a leaky fuel rail.
  16. #14
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Go to the nearest junkyard, there are AT LEAST 2-3 Devilles in there and minimum one had the SS line. I mean is a $20 repair in 45 minutes on the driveway. That in case the recall is not honored by dealer (mine wasn't). I have personally seen a '96 Eldorado burnt because of the fuel line.
    Mine was not to far when I did it 7 years ago.
    98eldo32v likes this.
  17. #15
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Yes GM makes SS fuel lines for your car, are the same as the one used for the '95-'97 recall. For $20 you can find one at your local junkyard (look for Devilles mostly).
  18. Remove Advertisements
