Heater Problem
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Heater Problem in Past Cadillac Vehicle Discussion; My 2002 ElDorado has developed a new problem. The driver side is getting warm air and the passenger side is ...
    Joe O is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado,1984 Seville
    Jan 2006
    Lancaster Pa
    34
    Heater Problem
    My 2002 ElDorado has developed a new problem. The driver side is getting warm air and the passenger side is cold.
    With our current weather, I need help on this one quickly!
    Thanks,
    Joe O
    Jwither's Avatar
    Jwither is offline Cadillac Owners Member
    Automobile(s): '97 STS
    Nov 2013
    79
    Re: Heater Problem
    Blend door actuators
    Looks like the same part that my '97 STS uses. I was able to take mine apart, move the motor and spin the gears, put it back together and it worked. YMMV. I think most of the time they just need to be replaced when they stop working, from what I've read.
    They were under the dash on the passenger side. You may have one on each side instead.
    This was of some help to me.
    My own thread on the issue.
    68
    82,062
    Re: Heater Problem
    That would be my guess as well. Pull the DTC's.
    Jan 2006
    Lancaster Pa
    34
    Re: Heater Problem
    How do you pull DTC's ? I have a scanner but all I can get is engine codes.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    See the "sticky" thread at the top of the Eldorado/Seville page on how to pull DTCs.
    Jwither's Avatar
    Nov 2013
    79
    Re: Heater Problem
    Sticky forum thread on pulling codes:
    Click here.
    A google image search shows your dash is similar to my '97 STS, that can't be right, can it?
    If yours looks like this, there's a section in that sticky thread that will help you:
  9. Remove Advertisements
