1999 STS vaccum leak?
Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 STS vaccum leak? in Past Cadillac Vehicle Discussion; Ok so this morning start the car I here a hiss from under hood and when I got off hwy ...
    jaybee86 is offline Cadillac Owners Member
    Automobile(s): 99 sts pearl
    Apr 2013
    baltimore,md
    30
    65
    Ok so this morning start the car I here a hiss from under hood and when I got off hwy it started to really rough idle at lights but fine while its rolling on hwy does that sound like hose or sumthing worse
    69
    82,402
    Re: vaccum leak?
    Have you opened the hood and snooped around? Tried to pin point the sound? Looked for broken or loose vacuum lines?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Re: vaccum leak?
    Check the PCV valve elbows on both heads and ends.
    PURPOSE
    A Positive Crankcase Ventilation (PCV) system is used to prevent blow-by gases from escaping to the atmosphere by routing them through a vacuum controlled ventilation valve, into the intake manifold. Fresh air from the air cleaner is pulled into the crankcase, mixed with blow-by gases and then combined with the air/fuel mixture and are burned in the combustion chamber.
    OPERATION
    The primary control is through the PCV valve which meters the flow at a rate dependent upon manifold vacuum. To maintain idle quality, the PCV valve restricts the flow when intake manifold vacuum is high. If abnormal operating conditions arise, the system is designed to allow excessive amounts of blow-by gases to back flow through the crankcase vent tube into the air cleaner to be consumed by normal combustion.
    SYSTEM FAULTS
    A plugged PCV valve or hose may cause:
    • Rough idle.
    • Stalling or slow idle speed.
    • Oil leaks.
    • Oil in air cleaner.
    • Sludge in engine.
    A leaking valve or hose could cause:
    • Rough idle.
    • Stalling.
    • Erratic idle speed
    Markosan likes this.
    Apr 2013
    baltimore,md
    30
    65
    Re: vaccum leak?
    I have and its coming from passenger side of engine but just can't tell exactly but hiss sound is towards fire wall. Are the vacuum hose big or small I'm not a car person like that so help plz
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Open the hood, stand on the passenger side, and look on the rear corner of the engine next to the coil packs. Removing the Northstar Engine beauty cover will help a lot.
    The elbows on these tend to crack some times
    Apr 2013
    baltimore,md
    30
    65
    Re: vaccum leak?
    Ok found problem hose but don't kno wat the hell to call it
    Apr 2013
    baltimore,md
    30
    65
    Re: vaccum leak?
    This is a pic of the hose I believe Vincentm was talking bout
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Thats it, inspect both of them closely
    Apr 2013
    baltimore,md
    30
    65
    Re: vaccum leak?
    This one broke completely when I touched it but what is this hose called n while I'm here do I need to change others or as they go?
    And is that metal part that come out with hose a sensor I need to replace or I just need hose
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    The PCV tube/hose. Take it to an oreilly or napa and get it replaced, elbows too
    Apr 2013
    baltimore,md
    30
    65
    Re: vaccum leak?
    Thanks you guys are the best ppl to have!
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Quote Originally Posted by jaybee86 View Post
    The metal part is the pcv valve itself.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Re: vaccum leak?
    It's the dirty air PCV vacuum line. It can be replaced with a length of proper ID reinforced rubber fuel hose. Have fun attaching it to the passenger end of the intake manifold. Check your PCV rattle valve, too - if it doesn't rattle, replace it ($2.50). FWIW, the 2000 and later engines do not have a rattle valve - it's a fixed orifice. No !
  16. #14
    Apr 2013
    baltimore,md
    30
    65
    Re: 1999 STS vaccum leak?
    Is there a certain way to get obvious valve back in?
  17. #15
    Feb 2006
    57,180
    The rattle valve has a large and small diameter. The large smooth end sticks into the cam cover grommet, the dirty air PCV line slips over the small end with retainer hump.
    Air flows through a PCV valve only one way: FROM the engine (cam cover) INTO the intake manifold.
  18. Remove Advertisements
