1998 STS Passenger front rattle
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1998 STS Passenger front rattle in Past Cadillac Vehicle Discussion; I am up dating my 98 Seville. It has a rattle somewhere in the passenger front wheel well I believe. ...
    jdemerich is offline Cadillac Owners Fanatic
    Automobile(s): 98 seville sts
    Jun 2009
    52
    103
    I am up dating my 98 Seville. It has a rattle somewhere in the passenger front wheel well I believe. I just replaced both front struts and mounts. It seem like it got worse. any ideas
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    What kind of rattle? And when does it do it?
    lizzardman is offline Cadillac Owners Member
    Automobile(s): 92 Seville and a 74 cadillac Eldorado Convertible
    Apr 2011
    Sedona Arizona
    42
    Re: 1998 seville sts Passenger front rattle
    Check the lower control arm stabilizing bar bushings.
  5. #4
    Jun 2009
    52
    103
    Thank you I will check that, the noise is hard to explain. when you ride down the road it's like thump thump thump thump thump thump, if that helps.New struts and mounts would be stiff at first, but I would think I would hear it on both sides if that were the case! In other words it's not continuous, but often especially going over bumps, and it was there before the new struts. my mechanic thought it was the mount. They were still bad and needed replacment
  6. #5
    Sep 2010
    East Boston MA.
    28
    26,325
    Sounds like sway bar link bushings, but that should have been obvious to whoever changed the struts.
  7. #6
    Jun 2009
    52
    103
    That's sad if that's the case.. Is the sway bar link the same thing as the lower controll arm stabilizing bar bushings?
  8. #7
    68
    81,740
    Re: 1998 STS Passenger front rattle
    The stabilizer "bushings" (insulators) are #29.
    The link bushings are either #19 or 20 and come included in the #37 kit.
    http://www.gmpartsgiant.com/Page_Pro...PartSortBy=Key
  9. #8
    Jun 2009
    52
    103
    Wow thank you so much for the detailed information!!!!!
    So the bushing would make a rattling noise when driving if bad, and not the sway bar link???
  10. #9
    68
    81,740
    Either one could be the culprit.
  11. #10
    Sep 2010
    East Boston MA.
    28
    26,325
    The links fail more often.
  12. #11
    Jun 2009
    52
    103
    Thanks again, I bought the link rebuild kit, I could for the sake of it change the bushings as well
  13. #12
    Sep 2010
    East Boston MA.
    28
    26,325
    Rebuild kit? Links are sold as assemblies. The bushings are what fail, but unless you're buying poly upgrade bushings, they're usually not sold separately.
  14. #13
    Jun 2009
    52
    103
    Sorry, it's a sway bar link with bushings and such. Has a long bolt 4 rubber type bushing looking things, about a 1" spacer, nut, 4 caps or washer looking things
  15. #14
    Jun 2009
    52
    103
    Well, back to ground zero.. My friend Don at Don't automotive put the car on lift. Sway bar is tight, bushings are good. Sway bar links have been replaced, but tight , no movement.
  16. #15
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Bushings (#29) may not be obviously bad upon visual inspection, especially when up on the lift.
  17. Remove Advertisements
