Overheating with full coolant
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Overheating with full coolant in Past Cadillac Vehicle Discussion; I have 99 cadillac sls with 105k miles on it. The radiator,cap,thermostat has been replaced brand new earlier this year. ...
    lacswerve's Avatar
    lacswerve is offline Cadillac Owners Member
    Automobile(s): 1999 SLS
    Jun 2013
    Jackson, Tennessee
    72
    ExclamationOverheating with full coolant
    I have 99 cadillac sls with 105k miles on it. The radiator,cap,thermostat has been replaced brand new earlier this year. Since then it's been fine, but now its overheating with full 50/50 coolant in it. It then starts to leak coolant on passenger side front end of engine when it started to overheat. I turned the car off but the computer takes over making the engine run idle and radiator fans on. I am curious to if it's a external/internal leak, water pump , thermostat,hose, or cap. No head gasket has been blown yet no visible or audible damage. Besides the leak underneath as stated above.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,706
    Re: Overheating with full coolant
    Quote Originally Posted by lacswerve View Post
    WHAT?
    pressure test the cooling system WHEN IT IS COLD -
    you can "rent" - for free - a pressure tent kit from autozone -
    or other parts stores -
    check the PURGE LINE for coolant flow -
    if you suspect failed head gaskets -
    do a BLOCK TEST -
    69
    82,287
    How do you know that the HG has not failed? Overheating is one symptom and the '99's are the worst offenders. The coolant "leak" you mention is probably overflow from the surge tank. IF that is the case, then get a block test kit (borrow one from AutoZone and just pay for the test fluid). That will tell you if it is a HG. IF it was not leaking from the overflow, then find and fix the leak point.
    lacswerve's Avatar
    Jun 2013
    Jackson, Tennessee
    72
    Alright I appreciate it and I assumed it's not a hg because my oil isn't milky.
    69
    82,287
    Northstar do not put coolant in the oil when the HG's fail so forget that.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Nor do they smoke in the early stages.
    lacswerve's Avatar
    Jun 2013
    Jackson, Tennessee
    72
    Ah I see
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Go down to Engines: Northstar and read the sticky threads on fans, cooling, gauge operation and head gasket failures. That will keep you busy for a while and answer a LOT of questions.
    I see where you tried to login with your never-activated username swervelac a little while back. That has been deleted form the CF database. Please continue to use lacswerve.
  11. Remove Advertisements
