Vibrating seville.
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Vibrating seville. in Past Cadillac Vehicle Discussion; Hey guys so recently my car started vibrating. It's weird because I can hear it more than I can feel ...
    kingjay's Avatar
    kingjay is offline Cadillac Owners Member
    Automobile(s): 1999 Seville SLS, 2007 STS-4 V.6
    Nov 2012
    Bonita Springs, FL
    26
    72
    Hey guys so recently my car started vibrating. It's weird because I can hear it more than I can feel it. I also feel like it's stronger once put in gear (reverse or drive) the car has new ac delco spark plugs, new wires all 4 new ignition coils, what could be causing the vibration? A motor mount? I haven't ran the codes just yet but I did so a while ago and I don't really remember seeing anything that would be the cause of this. Any help please? I'm just really trying to get this car to the best shape I can get it and the vibrating is annoying and kind of embarrassing (lol)
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Re: Vibrating seville.
    What's "vibrating" ??? The steering wheel, seats, body at speed or the engine at idle or upon acceleration ?
    Did you connect the coils/wires/plugs correctly ? Are the ICM ground wire terminals cleaqnm and tight ?
    68
    81,914
    Vibration is usually caused by a rotating part, tire or wheel imbalance is the most likely cause, but a bad front motor mount has been know to cause this.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    I believe you might be confusing the "audience" with your terminology -
    VIBRATING usually refers to rolling-related problems -
    out of balance tires - bent wheels - etc -
    and judging by your description - that is NOT it -
    if your "vibration" is happening at idle -
    you have a misfire -
    what can cause it? -
    vacuum leaks - dirty throttle body -
    defective new parts - LOTS of things -
    check for codes -
    kingjay's Avatar
    Nov 2012
    Bonita Springs, FL
    26
    72
    Sorry guys. Well to me it feels like it's vibrating, it only happens at idle. When I'm in park it happens also when I'm waiting at a red light or something. I checked the codes and there is no misfire code which is P0300 right? or something like that. Anyways also I didn't do the coils,wires,plugs myself so I'm not sure, but I mean when they were first done the car ran so smooth it was amazing and now all of a sudden this is happening.
    68
    81,914
    If it's at idle you can rule out wheels.
    A slight misfire will not set a DTC. When my '97 Deville had a misfire I had to brake torque it to 2000 RPM and hold it for a few seconds before it threw the P0300 and lit the MIL.
    kingjay's Avatar
    Nov 2012
    Bonita Springs, FL
    26
    72
    Man this sucks, I was hoping it wasn't a misfire but now I'm thinking it is, what do you guys think could be causing this?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Quote Originally Posted by kingjay View Post
    like I already said -
    COULD BE a bunch of stuff -
    coil - wire - spark plug - fuel injector - vacuum leak - dirty throttle body -
    kingjay's Avatar
    Nov 2012
    Bonita Springs, FL
    26
    72
    Quote Originally Posted by basscatt View Post
    Alrighty, well thanks Basscatt and to the rest of you. Tomorrow I will give it a good look and be back with more info
  12. Remove Advertisements
