Transmission fluid for 1970 Eldorado?
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Transmission fluid for 1970 Eldorado? in Past Cadillac Vehicle Discussion; What modern transmission fluid should I use for this car? Besides universal synthetics like Mobil 1 ATF....
    sgc2c is offline Cadillac Owners Member
    Automobile(s): 1970 Cadillac Eldorado 62k
    Jan 2008
    Boca Raton FL
    54
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    Re: Transmission fluid for 1970 Eldorado?
    DEXRON-VI is the new GM universal fluid as of 2006. It superseded the now-obsolete DEXRON-III.
    69
    82,159
    Quote Originally Posted by Submariner409 View Post
    Which if I'm not mistaken was the recommended trans fluid back in 1970 as well.
    Jan 2008
    Boca Raton FL
    54
    There's a Peak brand which says on the bottle "For Dexron III/Mercon applications" but says
    nothing about Dexron VI.
    Still it sounds like what you're suggesting I need
    for this car.
    Feb 2006
    56,568
    You can still find the - superseded - DEXRON-III on store shelves, so if you don't care to go with the recommended (GM) latest and greatest, use the old stuff.
    GM has a TSB on this.
    Jan 2008
    Boca Raton FL
    54
    The manual for the '70 Eldorado states the fluid
    capacity at only 5 quarts. Does that sound a bit
    low? I wonder if it's a misprint.
    69
    82,159
    Put 5 qts in it and check the dipstick.
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    Does not have to be Dexron VI, any fluid meeting Dexron spec III will do.
    1970 Cadillac Information
  11. Remove Advertisements
