Brakes sticking.....90 eldorado
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Brakes sticking.....90 eldorado in Past Cadillac Vehicle Discussion; this car sat around for about 5 years....I have flushed pond water out of tank... replaced fuel pump... filter.... water ...
    mikethemailman is offline Cadillac Owners Member
    Automobile(s): 1990 Eldorado
    Oct 2013
    41
    this car sat around for about 5 years....I have flushed pond water out of tank... replaced fuel pump... filter.... water pump.... batt .. serpentine belt....hoped I would be getting to the end but, the brakes wont release after you depress......someone helping thought the rear pistons were froze are they screw in ?? I cleaned the pins on front lubed w white grease....they definatly work just sticky....what is going on here ??
    rodnok01's Avatar
    Feb 2012
    NC
    6,595
    Re: Brakes sticking.....90 eldorado
    Can you narrow down frt or rear sticking? Could be anything from frozen pistons to bad hoses to MC.
    68
    81,761
    Quote Originally Posted by mikethemailman View Post
    Feb 2003
    california
    69
    6,613
    Calipers not releasing is usually restricted flex hoses to the calipers. Replace the hoses. They fill up with flaked off rubber and will stop brake fluid flow back to the master cyl.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    In my experience, this is most often a seized caliper more so than a hose.
    Either way, don't replace either blindly. Try turning the caliper piston in. If it's difficult, try it with the bleed screw open. If it moves with ease when the bleed screw is open, replace the hoses. If it is still difficult, replace the calipers.
    Feb 2003
    california
    69
    6,613
    And he's talking bout the REAR calipers. I was referring to the fronts sticking. Front calipers sticking..... usually hoses. Rear calipers loose, rattling..... seized pistons in the caliper from non use of the parking brake over a prolonged period.
    Oct 2013
    41
    THANKS GUYS ! I have bought new lines for the front...alrdy lubed front pins....I was schocked to see the rears very loose and sloppy.....they work (you can tell by rotors....3 parts stores in Omaha do not carry the hardware kits.....I imagine that's whats wasted...and then tightening E-brake am I on the right track ?
    Feb 2003
    california
    69
    6,613
    You MUST follow the adjustment of rear calipers by the book. The pistons in the caliper must be ratcheted out to take up normal wear clearance. Then lastly you tighten the parking brake cables. The levers the cables attach too on the rear caliper must be at rest against the cast in stop on the caliper with the parking brake fully released. If not, the caliper pistons will not ratchet out as designed as you use the parking brake each and every time you park the car! Most rear caliper issues come from non use of the parking brake. Pads wear, then pad clearance increases then the caliper rattles. There is a special tool that allows the piston to be ratcheted out assuming the piston is not already seized.
  11. Remove Advertisements
