Question about replacing part on rear suspension 02 Seville
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Question about replacing part on rear suspension 02 Seville in Past Cadillac Vehicle Discussion; I'm not sure what the name of part 26 is, connects to the control arm. Its pretty much the only ...
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,226
    I'm not sure what the name of part 26 is, connects to the control arm. Its pretty much the only original suspension component left on my car and I would like to replace it. The rubber is very warn on I feel like there is some rear sway. Do I need to drop the rear sub-frame in order to replace it? I don't think the rear sub-frame has ever been dropped and I worry about the bolts being rusted and snapping.
    69
    82,188
    Re: Question about replacing part on read suspension 02 Seville
    It's the rear suspension adjustment link. Not positive, but I think all you'll have to do is get a floor jack under #24.
    http://www.gmpartsgiant.com/Page_Pro...X=K&SortKey=10
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No subframe drop required.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,579
    Re: Question about replacing part on rear suspension 02 Seville
    you better order the adjusting cams too -
    parts 16 - 17 - and 18 -
    you will need two sets - one for each side -
    Sep 2003
    NY
    1,226
    When that is worn out, how does that affect the ride?
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    You do have to drop the rear of the subframe, the alignment bolts (item 16) holding the adjustment cams in place will hit the gas tank before they come all the way out of the subframe. Just remove bolts 19 and lower the rear edge by about 6 inches. Might as well replace those rear support bushings while your there. May have to pull your rear exhaust dwon a little, if so just undo the donuts at the rear bumper. I had my whole subframe out last year replacing those lower control arms, (that's what they are called), both rear control arms and all the bushings on my subframe, its not a horrible job as long as no bolts snap off.
  9. Remove Advertisements
