trunk latch keeps cycling
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, trunk latch keeps cycling in Past Cadillac Vehicle Discussion; hey i have a 99 eldorado and the trunk latch keeps cycling up and down with the trunk open, once ...
    crispy_chick3n is offline Cadillac Owners Member
    Nov 2013
    hey i have a 99 eldorado and the trunk latch keeps cycling up and down with the trunk open, once the trunk is closed the motor will stop cycling. i have never worked on or around one of these latches before, so i have no idea where to start. ive tried google, and mitchell1, and i havent gotten any useful information. any help would be appreciated, and ill try my best to answer any questions you have. thanks
    68
    81,889
    Re: trunk latch keeps cycling
    Sounds like a stuck switch. Check the pull down actuator switch. I think it's next to the latch.
    Nov 2013
    sorry for late reply, the trunk has been on the back burner. if you are talking about the switch that gets pushed down when the lid closes, i believe that one is fine. you can push it down with the trunk open, and it will stop the latch. i noticed a switch that the latch moves when it goes up and down, could that be the one you are talking about? if so is there a way to test it?
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,180
    Quote Originally Posted by crispy_chick3n View Post
    No, Ranger is talking about the latch switch on the decklid. Not the switch next to the actuator motor. They're a common failure item and cause the exact symptoms you describe. About $30 at the dealer.
  7. Remove Advertisements
