97 seville rear blown speakers
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, 97 seville rear blown speakers in Past Cadillac Vehicle Discussion; Hi i have a 97 seville and the back speakers are blown out. do u have to have an amp ...
    caddyman19 is offline Cadillac Owners Member
    Automobile(s): 97 cadillac seville
    Nov 2013
    1
    Exclamation97 seville rear blown speakers
    Hi i have a 97 seville and the back speakers are blown out. do u have to have an amp to power the new speakers
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: 97 seville rear blown speakers
    If you have BOSE sound system you actually need 2 amps to power the rear speakers (one for each). Base sound system has no amps is all in the HU.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    If you have the Bose speakers, like N* said they each have their own 2ohm speaker. Personally i'd replace them with Infinity Reference 9632CF's
    They're a direct replacement and will work with the Bose amps:
    http://www.amazon.com/Infinity-Reference-9632cf-Performance-Loudspeaker/dp/B002CIU78I
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Quote Originally Posted by vincentm View Post
    Is there a version for the front speakers as well?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The same goes for the front speakers only that if BOSE equipped not only that you have individual amps for each, but also enclosure.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    this is a 96 seville BOSE speaker. shows small amp mounted to speaker magnet
    red/yel wire is tap for my powered sub. which is gone now. yes, sub worked fine
    Playdrv4me's Avatar
    Nov 2003
    11,694
    Quote Originally Posted by N*Caddy View Post
    But I mean if you separate the driver from that amp enclosure it's encased in, is there an Infinity driver you can put in its place, or is the front door one a non-standard size (I see the rears are 6x9s)?
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by Playdrv4me View Post
    http://www.cadillacforums.com/forums...p-nominal.html
    Aug 2007
    mpls mn
    2,528
    I know Bose likes their tuned port enclosure design. Or folded horn or whatever. Still not sure if swapping in a different 4" speaker and using orig enclosure will make sound better? Sure, if old speaker is damaged it might help. Will replacing a good Bose with an aftermarket speaker make any diff?
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    My fronts sound alot better with the Infinities than the Bose. Louder and more clear, better highs with the tweeter enabled on them.
    Playdrv4me's Avatar
    Nov 2003
    11,694
    Eh, I may try it at a later time. I confirmed my suspicions today about the somewhat disappointing sound on my '92. The speakers are all perfectly fine, but the problem is that some idiot Delco engineer decided to include Dolby B NR with NO ability to defeat the noise reduction. I always suspected that this was the case based on the telltale "warble" of clarity in some passages of music with the cassette adapter, but for some reason I didn't actually notice until tonight the "DOLBY B NR" logo on the cassette door, most likely because I couldn't see it. Those factory Bose speakers do an admirable job for being tasked with so many frequencies in such a simple design, and I think with a proper input, they'd be fine.
    So now my choices are to fab up a permanent line-in somehow or replace the HU with an aftermarket unit which I DO NOT want to do. A third option would be that if that if any of the subsequent years of Delco Bose Gold HUs had CD changer options (I'm rather certain '92 never did) I could swap in a later HU and hijack the CD changer input to add an AUX. Normally the Philips tape adapter sounds fantastic, but if you add Dolby NR it ruins it.
    EDIT: From the looks of this old thread: http://www.cadillacforums.com/forums...nger-ipod.html
    It would seem that '94 did have a CD changer, but I sure can't find any information about it or the product they're talking about.
    Warspite's Avatar
    Warspite is offline Cadillac Owners Fanatic
    Automobile(s): 1962 coupe (selling), 1995 Seville SLS, 1966 Sedan DeVille
    May 2010
    Atlanta, GA
    57
    244
    I had that Delco Bose Gold HU in my '95 - and it did NOT have a changer option (single CD player in the HU). Oddly, it did NOT have external amps, and the speakers were 10 Ohm. I replaced the entire system, with a JVC head unit, remote tuner bypass harness, and Rockford Fosgate speakers all around.
  15. Remove Advertisements
