lower control arm available ? 90 eldorado
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, lower control arm available ? 90 eldorado in Past Cadillac Vehicle Discussion; I may not be calling it the correct term.....the lowest component under the drivers side strut.....has a big control arm ...
    mikethemailman is offline Cadillac Owners Member
    Automobile(s): 1990 Eldorado
    Oct 2013
    41
    I may not be calling it the correct term.....the lowest component under the drivers side strut.....has a big control arm that passes thru the frame....Cadillac has discontinued,........my parts store says NO-DICE ! I saw a site here for old caddie parts or if a member has a used one.....need to get her rolling!!!! mike in Omaha
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    Re: lower control arm available ? 90 eldorado
    Mike:
    Used lower control arms for these vehicles are pretty common as they were also used in other GM vehicles. Look on eBay for starters -- I bought a set about two months ago from the Cadillac King website. I would expect to pay about $75-$100 each.
    Oct 2013
    41
    got 1 from Ebay today (oldsmobile) 60 plus 17 shipping no bolt or front bushing is that available or is it just a bolt and washer on front side of frame mike
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    There is a washer and bushing on each side of the frame - it all gets sandwiched together when you tighten the nut on the control arm. The bushings and washers are sold as a set and are called the strut rod bushings.
    That aforementioned nut was a lock nut from the factory. If you don't replace it, at least put some threadlocker on it.
  7. Remove Advertisements
