1997 STS problems.
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1997 STS problems. in Past Cadillac Vehicle Discussion; Hi, I have a cadillac sts 1997. My trunk button doesn't work, nor does my gas tank button that's on ...
    tezepremillz1293 is offline Cadillac Owners Member
    Automobile(s): sts cts
    Jul 2013
    24
    33
    1997 STS problems.
    Hi, I have a cadillac sts 1997. My trunk button doesn't work, nor does my gas tank button that's on the dash work. What could be thr problem? also, I changed my car spark plugs but not the wires, Also Does it matter what brand of wires I use?. Please help. I'd truly appreciate cadillac enthusiast. Also how much would you say 1997 cadillac sts is worth in excellent condition with 185 thousand miles on it?
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: 1997 cadillac sts problems.
    Quote Originally Posted by tezepremillz1293 View Post
    To answer your last question, we sold our last 1992 green STS (same body, different motor) with 192,000 miles on it for $1300.00. My brother put a sign on it in KS, left it in his driveway before he was even ready to put it out somewhere for sale, and his phone would not stop ringing. So assuming it's not riddled with problems or rust, on paper it's worth 1200-1500.00 easily, even at nearly 200k. Ultimately, it's worth what someone is willing to pay.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,848
    Re: 1997 STS problems.
    Trunk and fuel door buttons = Valet switch in the glove box.
    www.kbb.com for pricing and be honest on condition.
    If you want the "best" plug wires go with the AC Delco set ($100 +/-) from RockAuto. Use this to get the correct plug connected to the correct coil tower.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,350
    make sure the VALET switch in the glove box is OFF -
    then check all the fuses -
    absolutely -
    I HOPE you used ACDelco plugs -
    and I recommend ACDelco wires -
    no car on the planet with 185K miles on it is in EXCELLENT CONDITION -
    but - assuming EXCELLENT condition - for a car with 185K miles -
    with great paint - no rust - no dents - descent interior - descent tires -
    no mechanical issues - $800 to maybe $1200 - DEPENDING ON WHERE YOU LIVE
    ask yourself this -
    if YOU were looking for a used car -
    what would YOU pay for this one - HONESTLY -
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    If it is actually in excellent condition, meaning most parts have been replaced and it's mechanically sound with NOTHING wrong with it I would say $2,000-$3,000 tops.
    Here's what excellent means;
    Looks new and is in excellent mechanical condition
    Has never had any paint touch-ups and/or bodywork
    Does not need reconditioning
    The engine compartment is clean and free of leaks
    Is free of rust
    The body and interior are free of wear or visible defects
    Wheels are flawless
    All tires match and are like new
    Has a clean title history and will pass a safety and smog inspection
    Has complete and verifiable service records
    Most used cars come no where near this condition so I doubt a 16 year old car could be unless its been garaged its entire life and meticulously cared for by one seriously anal owner.
    You're probably looking at more like $1,500.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    A 97 with 185k miles and original headgaskets, fuel pump, shock absorbers, transmission? Can you say all these old parts are in excellent condition just because they work?
    Jul 2013
    24
    33
    Quote Originally Posted by basscatt View Post
    absolutely -
    ask yourself this -
    do you know what fuse would go to the trunk and fuel box
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    fuse location starts on page 6-58 of the Owners Manual -
    if you don't have one -
    it looks like there are two fuses in the trunk -
    the RADIO/PHONE fuse covers -
    Radio Receiver, Radio Interface
    Module (RIM)(,Bose Only),
    Phone, DAB Relay, Trunk Release
    Relay, Fuel Door Release Relay,
    High/Low Beam Relay
    the other one is the CONVENC fuse -
    Trunk Release Relay, Trunk
    Release Solenoid, Fuel Door
    Release Relay, Fuel Filler Door
    Release Solenoid, Door Lock
    Relay, Left Front Door Motors,
    PZM, Door Unlock Relay
    Jul 2013
    24
    33
    also can you guys tell me what would make my driver side heated seat not work my passenger side works.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    I bad heating element more than likely. Does the seat make a clicking sound every 30s or so? Thought this thing was in excellent condition?
    Feb 2006
    55,848
    One or both heating elements are broken. Several How-To fix it threads in Cadillac Tech Tips. Disassemble the seat, find the breaks, solder in jumper wires.
    - or - check the heated seat module connectors under the seat.
    Google "cadillac forums seville heated seat repair" or something close.
    The seat pad heater diagraqm is the new replacements in the field - NOT the originals
    Click on a thumbnail, use your browser <- to back out.
  14. Remove Advertisements
