STS 2001 interior lights problem
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, STS 2001 interior lights problem in Past Cadillac Vehicle Discussion; Some of interior lights don't work But doors lighting works I mark it withe red pin 6gg.jpg The problem began ...
    power007 is offline Cadillac Owners Member
    Automobile(s): STS 2001
    Jun 2011
    43
    ExclamationSTS 2001 interior lights problem
    The problem began after I replace my Car Radio withe an aftermarket
    sorry for my bad English
    68
    82,056
    Re: STS 2001 interior lights problem
    Normally I would venture a guess at a bad IP ground, but since it happened right after a radio installation I would tend to think it is self inflicted. I'd go back over all the wiring you touched.
    Jun 2011
    43
    thinks man i will Check that
    But is it possible to be a Fuse and how I find it
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It might be a fuse.
    How do you find what?
    Jun 2011
    43
    It might be a fuse.
    the Fuse
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    I had this exact same situation happen on a 2006 Escalade I installed an aftermarket radio into. I touched a wire on the harness to something (very vague memory) and I lost nearly all the same lights. I never did figure out what fuse or circuit controlled the lamps that died before I sold it unfortunately. But to echo Ranger's point, it was almost definitely your radio work that blew something on that circuit.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,473
    Quote Originally Posted by power007 View Post
    the Fuse
    fuses are under the back seat -
    Jun 2011
    43
    I have solved the problem Thank you all I found the fuse
  11. Remove Advertisements
