DTC P1645 EVAP Solenoid Output Circuit
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, DTC P1645 EVAP Solenoid Output Circuit in Past Cadillac Vehicle Discussion; I keep getting code P1645. I'm not sure I understand this one. Is this usually a simple fix? Thanks...
    ROCKnROLL's Avatar
    ROCKnROLL is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Nov 2003
    Louisville, Ky.
    48
    Thanks
    Mike G is offline Cadillac Owners Member
    Apr 2005
    Littleton, CO
    13
    Re: DTC P1645 EVAP Solenoid Output Circuit
    Refers to evaporative emission controls. Could be the vacuum purge switch or the EVAP control solenoid. Check the ECS fuse in the engine compartment block or the fuses on the main panel. The solenoids are mounted on the top side of the motor so if they need replacing, it should be doable.
    --Mike
    ROCKnROLL's Avatar
    Nov 2003
    Louisville, Ky.
    48
    Quote Originally Posted by Mike G
    --Mike
    Thanks for the reply Mike.
    The fuse was OK.
    You're right, they are easy to get to, right next to the EGR valve.
    Is it possible to get the part #'s from some place on the forum or from someone?
    Thanks
    Rock
    68
    82,068
    ROCKnROLL's Avatar
    Nov 2003
    Louisville, Ky.
    48
    Thanks Ranger.
    Is this 1998-2004 parts list going to be accurate for a 97 seville?
    The two parts I need info on are:
    evaporative emission control solenoid
    vacuum purge switch
    Thanks
    68
    82,068
    I would think that they are the same but you might want to cross check the numbers with you local Cadillac parts dept.
    cadillacjoel23 is offline Cadillac Owners Member
    Automobile(s): 02 sts
    Jun 2013
    NC
    30
    67
    is there a diagram showing how to connect the solenoid back up correctly..i think theres a vacuum hose missing somewhere
    68
    82,068
    For which car? You have two listed.
  11. Remove Advertisements
