2000 STS - multiple DTCs
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS - multiple DTCs in Past Cadillac Vehicle Discussion; Hello all, I am looking for some expert help and I know I can find it here. I am a ...
    Rick88 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jan 2012
    49
    5
    Hello all,
    I am looking for some expert help and I know I can find it here. I am a mechanic
    (aircraft/my own vehicles/etc) for 30 + years but this cadillac is a whole new animal that I am looking into. I am trying to help a friend with her cadillac, it is a 2000
    STS and the airbag light is on, the ABS light is on and also the Traction light stays
    on and the service engine soon light was on. She said something is running the
    battery down overnight as well, I did have to jump it this morning. I pulled the
    codes with an OBD II reader and they were P0340 and P0385, I pulled the codes
    from the DIC and it showed 2 current codes; ABS C1232 and IPC U1000. I erased
    the P codes yesterday and drove the car to work and back today (about 65 miles
    round trip) and the service engine soon light is still out, but I do still have the ABS,
    airbag, and traction lights on all the time. Any guidance in these matters would be greatly appreciated.
    Rick
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,550
    Well you aren't in the correct sub section of the forum. But I know that a weak battery can cause lots of random codes and issues to come up. The battery as you may have noticed is under the back seat cushion (just pull up on it and it pops off) and is a vented battery if you don't get the right kind you will cause the seatbelts and the seat bottom to breakdown from the acid fumes.
    It may or may not fix the issues but it's a start.
    Sent from AutoGuide.com App
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    A bad battery can definitely cause random/false codes. Make sure you don't have a low voltage problem first.
    Please list the code definitions, we don't quite know them all by heart yet . . ABS and TCS lights together are usually a wheel speed sensor.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,875
    Re: 2000 sts
    Moved from the new 2005+ Sigma body "STS" to the Seville forums.
    69
    82,286
    Re: 2000 STS - multiple DTCs
    Forget the code reader and just use the DIC. It'll be more accurate.
    If you suspect a current draw connect a test lamp in line and start pulling fuses until you find it.
    P0385 looks familiar. I think that may be a CKP sensor. P0340 may be related as well, but I can't remember for sure. The code definitions you post will tell, but GM had a bad supplier from 2000+2003. They all need to be replaced eventually.
    Jan 2012
    49
    5
    Okay, update. The P 0340 code did not come back after clearing it, I think because the starter solenoid was acting up and it wouldn't start for a couple of tries, then it started fine. Cleared that code and it's good. I still have the ABS C1232 code for left front speed sensor short-circuited or open. Also have the IPC U1000 for class 2 communication malfunction. I am getting 2.0-2.3 volts to speed sensor (same as right side) so I tried another hub assembly (from junkyard), same results. Can anyone share a diagram of that system with me? If this was my vehicle I would subscribe to all data but just trying to help a friend.
    Thanks,
    69
    82,286
    Are you looking for a diagram or a wiring schematic? I can post a diagram.
    There IS a possibility that the junkyard hub had a bad sensor as well. Did you check continuity on either of them?
    Jan 2012
    49
    5
    Ranger, yes sir, I checked continuity on both of them and none present on either. I wanted a schematic to see how the system works for myself, had a friend say there had to be voltage going to it but I figured a sensor circuit should have continuity at all times if the sensor was good. Any insight is appreciated.
    Thanks,
    69
    82,286
    That is starting to jog my RAM. I thought the same thing, but now that you mention it, I think I recall a discussion about this not to long ago and I was corrected. Can't swear to it, but you may have to spin the hub to get continuity. Don't ask me to explain it.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by Rick88 View Post
    No continuity = two bad sensors. Measured with the sensor disconnected from the vehicle wiring.
    Basically, the wheel speed sensor is a coil surrounding a toothed magnetic rotor. The rotor teeth impose a series of low voltage pulses as the hub rotates. The EBCM counts the pulses and calculates a wheel speed value.
    No continuity means no pulses = a DTC for that wheel speed sensor.
    69
    82,286
    So we ARE correct in assuming that there should always be continuity? I just changed one for JimmyH and I think there was no continuity on the bench and it was a brand new unit.
    Sep 2003
    Metro ATL
    4,854
    The wheel speed sensor circuit external to the EBCM is about as simple as a doorbell. Find it under ANTILOCK BRAKES in the Service Manual.
    No continuity on a new unit makes me suspicious something else was happening there; bad ohmmeter connections or faulty ohmmeter or failed ohmmeter battery or pilot error. Or something.
    Jan 2012
    49
    5
    Thank you gentlemen, I will back track and double check it while spinning the hub. I had previously checked for continuity statically. Thank you all for the help, I will report findings.
  16. Remove Advertisements
