RS0060 Code
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree4Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, RS0060 Code in Past Cadillac Vehicle Discussion; I have been pouring over the past discussion of this code. I have a '96 Eldorado (SUbmariner's favorite year RS0060 ...
    Markosan's Avatar
    Markosan is offline Cadillac Owners Member
    Automobile(s): 1996 Eldorado ETC
    Oct 2013
    OH10
    44
    RS0060 Code
    RS0060 - Left Front Position Sensor Fault - Current
    It was in my History but it came up Current again today.
    Some folks creatively bypass the sensor by rewiring, I will first try to clean it.
    Is this the sensor in the strut? Is it anything to really worry about?
    Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    There are no sensors in the struts. The sensor is in the wheel well, connected to the lower control arm with a small connecting rod.
    The stability system and RSS system will be disabled if the code is current.
    If you don't know where the sensor is, how do you know someone's messed with the wiring?
    69
    82,393
    Re: RS0060 Code
    Markosan likes this.
    Markosan's Avatar
    Oct 2013
    OH10
    44
    Re: RS0060 Code
    MC, I was referring not to my car but to a discussion I found about working around this sensor.
    http://caddyinfo.ipbhost.com/index.php?showtopic=15870
    Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,171
    Re: RS0060 Code
    Hmmmm ............. C 0060 is "LF ABS solenoid circuit #1 malfunction" in the OBD2 DTC list. "RS0060" is not a DTC.
    RS C codes (suspension parts height and function) don't begin until 05XX.
    OBD1 was used until 1996, then the codes changed over to OBD2 (OBD-II). Some 1996 (early) vehicles use a weird mix of DTCs.
    69
    82,393
    Re: RS0060 Code
    '96 has a combination of OBDI & OBDII
    I think it is an OBDI S code (Road Sensing Suspension (RSS) Codes).
    S060 .............................................. Left Front Position Sensor Fault
    Markosan's Avatar
    Oct 2013
    OH10
    44
    Re: RS0060 Code
    My Eldo was made in Feb. of '96, right on the cusp and it is tough to figure this out. I am going by the others before me who have had a RS0060 and call it a Left front Pos. Sensor. Some folks drop the R and call it a S060 code... I can't find a list anywhere for RS or S codes. I am gonna clear the codes and see what happens.
    Sep 2010
    East Boston MA.
    29
    26,323
    A 4 number code is OBD II. RS translates to a C code.
    C0060 - Left Front ABS Solenoid #1 Circuit Malfunction
    Feb 2006
    57,171
    Re: RS0060 Code
    February of 1996 was 4 months before the end of the '96 model year. Technically, your car is a "late" 1996 model.
    This is November of 2013 and many of the "2014" models have been on the street for 4 months already.
    69
    82,393
    Re: RS0060 Code
    Quote Originally Posted by Markosan View Post
    http://z-cut.de/US/dtcobd1.html
    Markosan's Avatar
    Oct 2013
    OH10
    44
    Re: RS0060 Code
    Thanks very much. I cleared everything and will see what comes back on tomorrow's commute. I did manage to swap out my tattered dog bone torque struts today.
    So is this a problem with the sensor or the actual hardware?
    69
    82,393
    Re: RS0060 Code
    No, if your code is S060 then it's an OBDI code for .............................................. Left Front Position Sensor Fault. Give us the exact code you have. Is it S060 or C0060?
    Sep 2010
    East Boston MA.
    29
    26,323
    It's an electrical problem in the solenoid circuit. It could be the solenoid inside the EBTCM, circuitry, or a wire external to the EBTCM. I'd try inspecting and cleaning the connector first.
  16. #14
    Markosan's Avatar
    Oct 2013
    OH10
    44
    Re: RS0060 Code
    It comes up as "RS 0060 Current" I did clear the codes and will see what comes up again.
  17. #15
    69
    82,393
    Re: RS0060 Code
    That sounds like an OBDI code which would be S060......... Left Front Position Sensor Fault. An OBDII code would have a P, B, C or U prefix.
  18. Remove Advertisements
