  Follow CadillacOwners on Twitter
Cadillac Forums: "no acm data" heat and air not working
Old 05-04-05, 02:42 PM
View beejay's Photo Album
Casino Cash: $250
Red face "no acm data" heat and air not working
I have a 1997 eldorado touring coupe (etc). One of my remotes broke and I purchased a new one. I followed the instructions that came with the remote (going through the diagnostics system.) I was able to tune in the remote and it works fine. Now the analog climate control cluster will light up for a few seconds when I start the car, then it goes blank and shows 2 dashes on the left and right of the panel. The heater and air won't work. When I go through the diagnostics mode, it shows "no acm data". Could someone help me with this?
  #2 (permalink)
Old 05-04-05, 03:21 PM
mtflight's Avatar
Cadillac(s): 2003 White Diamond DHS
View mtflight's Photo Album
Casino Cash: $5110
Re: "no acm data" heat and air not working
I'm not sure how you use Diagnostic mode for programming the remote (would love to know how though). If this was directly related (AC stopped working after programming the remote) then I would look IPC Override at the Option sections under IPC in the Service Manual. I successfully de-activated my phone (which was controlling the left side steering wheel paddles) through these.
If you don't have the service manual, I can probably send you the section via e-mail.
I have a remote that I purchased and have no idea how to program it...a Chevy dealer wanted to charge me $100 . Can you send me the instructions, please?
mtflight @ gmail . com
Thanks, and good luck!
P.S. One time, I accidentally disconnected a ground cable to the engine (while replacing the infamous blower motor), and then no sound was coming from the stereo. The DTC referred to a problem with ground, and also a "no signal from amp. " I fixed the ground to no avail... until I thought to disconnect the negative battery for about a minute, then reconnect it. Stereo worked again!
  #3 (permalink)
Old 05-04-05, 04:19 PM
STS 310's Avatar
Cadillac(s): 1996 STS
View STS 310's Photo Album
Casino Cash: $252
By all means, BE CAREFUL in the diagnostic mode. You can permanently damage modules (which you may have done).
Tags: , , , , ,
air, heat, no acm data, working
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
