1993 Eldorado Alignment specs
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1993 Eldorado Alignment specs in Past Cadillac Vehicle Discussion; I just swapped out the struts on my 93 Eldorado. I changed it from the factory worn out ride control ...
    tedgley is offline Cadillac Owners Member
    Automobile(s): 1993 Eldorado
    Dec 2012
    54
    7
    I just swapped out the struts on my 93 Eldorado. I changed it from the factory worn out ride control to Monroe Sensatracs. Now the car seems to not roll as freely going in a straight line and when I go around just the slightest curve, the inside wheel squeals. Also, the steering wheel is pointing about 5 degrees to the right when car is headed straight.
    I have looked as best I can for the alignment specs for this car, but have not found them on here. I have the tools to check camber and toe. Can anyone tell me what the factory specs are for these and any pointers on how to adjust?
    thx
    JackFunTeach is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ETC, 2001 Eldorado ESC Custom Project, and ...
    Sep 2013
    North Central, MA (near Orange
    53
    78
    Re: 1993 Eldorado Alignment specs
    I have the alignment spec for my 2001 and 2002, I can fax the sheet to you if it would be helpful. I just don't know if they would be the same as yours, though.
    Jack
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    The strut/knuckle joint on my 96 has a lot of adjustment when u remove/loosen knuckle bolts. U can really get camber out of whack if u want to. That has a major effect on that wheels toe. U tweak camber and toe changes while u do it. Very hard to adjust both in your driveway. I have tried. I use the NASCAR string method for toe.
    Dec 2012
    54
    7
    Ended up just taking to alignment shop. I could've set the toe easy enough, but wasn't comfortable with setting camber.
    thanks for the replies
    Aug 2007
    mpls mn
    2,527
    you should post alignment specs now that you have numbers. if anyone does a search for your post, they can see the values.
    Dec 2012
    54
    7
    they didn't give me any numbers and I didn't think to ask. I guess I could give them a ring and see if they can tell me (Tire Discounters).
    good idea though
  9. Remove Advertisements
