P0441 Evap purge flow
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, P0441 Evap purge flow in Past Cadillac Vehicle Discussion; CEL light comes on, code is in history, all vacuum lines are snug and tight, i clear code, CEL goes ...
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    CEL light comes on, code is in history, all vacuum lines are snug and tight, i clear code, CEL goes away, but when it comes back the code goes to history right away.
    any ideas?
    68
    82,064
    Re: P0441 Evap purge flow
    I think that is one of those codes that is "current" only while the PCM is commanding the purge solenoid open and it fails. Once the PCM removes the purge command, it goes to history. At least that's my suspicion.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Checked all connections and vacuum lines connected to the Evap solenoid, and my PCV valves, all is tight and snug. Do these Solenoids tend to fail?
    68
    82,064
    I don't think it is a common failure, but anything can fail.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    hmm, true, very true
  8. Remove Advertisements
