2001 SLS - MAF code - runs rough
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 SLS - MAF code - runs rough in Past Cadillac Vehicle Discussion; Hi guys, I currently have a p0102 code on my 01 sls I have since replaced the maf itself cleared ...
    jc6553 is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS
    Jan 2012
    23
    Hi guys, I currently have a p0102 code on my 01 sls I have since replaced the maf itself cleared code yet still have the ses light and still get the occasional hesitation. Where should I look next?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Please don't hijack threads. Feel free to start your own.
    69
    82,383
    Re: 2001 SLS - MAF code - runs rough
    Plugs, vacuum leak, dirty TB.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Yeah, That ^^^^
    .......... and any air leak in the intake ducting at or after the MAF - or that dumb resonator spigot - WILL set MAF codes.
    Jan 2012
    23
    I saw that butt plug setup the other day on moists pics just wondering if it's just a 2" PVC cap with stainless clamp?
    Feb 2006
    57,139
    Yep. The one in the picture is actually a rubber pipe cap - $1.85 at Ace hardware, with clamp - but you need to fill it with a solid plug to keep it from collapsing - I now use a slightly domed PVC pipe cap painted semi-gloss black.
    Find a suitable machine screw to replace the rubber Torx bolt at the PCM cover.
    69
    82,383
    I used the PVC pipe cap on my daughters '04 SLS and it doesn't even need a clamp. I went with flat black and it almost looks OEM.
    Jan 2012
    23
    Just tossed the cap in the car does seem to run better cleared the code yet I still have the ses light any other ideas?
    Feb 2006
    57,139
    IF you have not actually gone into the car's built in code system and manually "clear codes" it will take 3 start-run-drive cycles for the SES to extinguish IF there are no other emissions or powertrain performance faults/codes set.
    OK - I see you did clear codes. Something else is fishy.
    Jan 2012
    23
    Ya quite odd perhaps I have a bad ECM? Is that possibly? I've since drove around the city and I haven't felt hesitation and it runs much quieter yet still a ses
    69
    82,383
    PCM's are pretty reliable, but anything can fail.
  14. Remove Advertisements
