Buttons/illuminate?
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Buttons/illuminate? in Past Cadillac Vehicle Discussion; 2000 Seville Had the car for a few weeks. Just dawned on me that there is no illumination on the ...
    BigErn23's Avatar
    BigErn23 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Seville STS, 2007 Cadillac Escalade
    Sep 2013
    Chicago
    37
    86
    Buttons/illuminate?
    2000 Seville
    Just dawned on me that there is no illumination on the info/trip/KM MPH/Temp control/ front seat heater buttons (the rear are illuminated)....at night with head lamps ON.
    ....can't recall if they were working before.
    Is there a setting for this maybe I turned off somehow?
    Fuse blown? Or maybe they just aren't illuminated buttons?
    Anyone? Please advise.
    Thanks.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Check the fuses under the rear seat cushion, including the one labeled DIM.
    If the fuses are good, the "rice grain" (named for their size and shape) are out. You can replace them if you don't mind soldering. Otherwise, you'll need to replace the buttons.
    BigErn23's Avatar
    Sep 2013
    Chicago
    37
    86
    Thanks for reply.
    (So ur saying they Should be illuminated, it sounds like)
    I'll check that fuse when I get the chance.
    I'm hoping that it's a fuse, since not one of the buttons is illuminated.....I doubt they are all burned out.
    Thank you!
  5. #4
    68
    81,755
    Re: Buttons/illuminate?
    Yes, they should illuminate. I doubt it's a fuse. That would take out more than just 3 buttons. Not sure what bulb those are. I just did a console button and all 6 steering wheel buttons on an '04. If it's the same type of bulbs, it's micro surgery soldering (tweezers and magnifying glass).
  6. #5
    BigErn23's Avatar
    Sep 2013
    Chicago
    37
    86
    Thank you.
    I appreciate the info.
    .....sorry if I was unclear, but ALL buttons I listed before are not lit up.
    (Not just 3)
    In the event I need to solder I may need to come back for more advice in how to do so. Thanks.
    I'll check fuses and keep u guys posted.
  7. #6
    68
    81,755
    If you need to solder in new bulbs and you do not know how to solder, I would strongly advise replacing the switch. Like I said, it is micro surgery and you are soldering the bulb onto a very small printed circuit board. That said, all those bulbs at once is not likely. You need to find the common denominator, fuse or ground maybe.
    Just to give you an idea of what I was talking about. Here is one of the steering wheel bulbs.
  8. #7
    BigErn23's Avatar
    Sep 2013
    Chicago
    37
    86
    Thanks again Ranger.
    I'll look into the fuse tomorrow and hopefully solve the issue.
    Otherwise I'll be bugging you in the near future.
  9. #8
    3redlines is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V, 2005 STS 1SG, 2005 STS 1SC, 2004 SRX AWD MRC
    Apr 2012
    North Mississippi
    57
    95
    Do your headlamps turn on automatically when it gets dark?
    I get no button illumination until twilight sentinel detects it's dark enough outside.
    The light sensor for the twilight sentinel on my 01 SLS is going bad, it has to be pitch black outside before my auto headlamps come on. Until then there is no button illumination even with the headlamp switch turned on.
  10. #9
    bwv565 is offline Cadillac Owners Enthusiast
    Automobile(s): HAD a miserable Catera and even worse 2003 STS
    Jan 2013
    Toronto
    603
    Quote Originally Posted by 3redlines View Post
    Same here, and one of the buttons on the steering wheel has no more illumination (backlighting).
  11. #10
    BigErn23's Avatar
    Sep 2013
    Chicago
    37
    86
    I believe my sentinel is fine.
    I checked the fuse today and it was toast.
    Put another one in and it blew.
    I'll have to do some troubleshooting tomorrow.
    .....but I guess at least it's better than soldering all them little lamps.
  12. #11
    68
    81,755
    Quote Originally Posted by BigErn23 View Post
    IF you can find the short.
  13. #12
    Sep 2010
    East Boston MA.
    29
    26,325
    Which fuse?
  14. Remove Advertisements
