Results 1 to 9 of 9
Thread: 97 Head gasket
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    97 Head gasket
    Using coolant, rough cold start, blowing white smoke. I think this car is done. The car runs and drives perfect not sure what I should do with it. Any suggestions? The body is good, engine runs fine with aforementioned issues, everthing else works. No engine codes, only one body code. What should I do with it? 165000
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Re: 97 Head gasket
    Block test it to confirm is the head gaskets, and keep in mind the issue is repairable, depends on how much you're willing tos pend to keep her on the road, noone can answer that for you...
    69
    82,272
    Re: 97 Head gasket
    You have all the symptoms. Minimum repair cost will be about $2000. Tough call on a '97 with 165K.
  5. #4
    Jun 2010
    Rochelle IL
    302
    What damage will I do if I keep driving it? As long as it does not over heat.....drives fine after a warm up period.
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    No damage unless it starts consuming enough coolant to hydrolock.
  7. #6
    Jun 2010
    Rochelle IL
    302
    Quote Originally Posted by MoistCabbage
    What is hydrolock?
    What is hydrolock? The coolant mixes with the oil or what?
  8. #7
    69
    82,272
    Re: 97 Head gasket
    Hydrolock is when enough coolant gets into the cylinder that it fills it when at TDC. Coolant, being a liquid is not compressible so something has to give as seen below. Rod broke and came through the side of the block.
  9. #8
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Re: 97 Head gasket
    Hydrolock can also occur when "mechanics" get carried away with various cleaner sprays and carbon cleaning fluids. (Fortunately the Northstar intake manifold - lower log runner - holds a LOT of fluid)
  10. #9
    69
    82,272
    Re: 97 Head gasket
    That is exactly how the above happened. Ring cleaning procedure that went wrong.
  • You may not post replies
