1996 eldorado trans problems
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1996 eldorado trans problems in Past Cadillac Vehicle Discussion; Help. Got a code 0717 which is input speed sensor. Can anybody give me info on how to replace. I ...
    skontos is offline Cadillac Owners Member
    Apr 2005
    Help. Got a code 0717 which is input speed sensor. Can anybody give me info on how to replace. I can reset code but now it comes right back, but trans seems fine shifts ok. I'm also looking for some good shop manuals. Thanks. And if anybody has some good pictures of sensor that would help too.
    addison_ii's Avatar
    addison_ii is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Sedan Deville
    Mar 2005
    Twin Cities, Minnesota
    35
    2,146
    Re: 1996 eldorado trans problems
    http://www.caddyinfo.com/howto/pc0717.htm, is the address you can go to find pics.
    But here is the info on how to replace:
    The speed sensor can be changed without removing the transmission from the car. The engine/transmission can be lowered to access the transmission side covers and the end plate. It is located inside the transmission. The sensor is located next to the sprocket for the input shaft. The sensor is held in place with 2 6mm bolts, one for the sensor, one for the wiring harness.
    If you decide to try this job yourself I would recommend going to a transmission rebuild shop, or look on the Net for an overhaul manual for this transmission, they are about US$15.00. These will give torques, diagrams and assembly practices for this transmission. The manual will not cover just removing and replacing the sensor, it covers a complete overhaul. That is why I built this how-to section, it will give you an idea where it is at, and save you some time.
    Before getting started I recommend cleaning the engine externally. Once the side covers are off the transmission it is easy to knock debris into the transmission while working in the wheel well.
    The first thing that needs to be done is to put the car on jack stands. Jack the car up, and put the jack stands under the body frame, just behind the engine cradle. If you support the car on the engine frame you will not be able to lower the engine!
    You will either have to remove the hood, or disconnect the hood strut rods to allow the hood to be opened farther than it normally does. I disconnected the strut rods, and raised the hood carefully, and then tied off the hood to the A frame that I used to lower the engine. This allows for clearance between your hoist and the hood. Now is a good time to disconnect the battery.
    The engine has to be lowered, you can use an “A” frame, cherry picker or overhead hoist. The overhead type hoists allow for easy access to the engine compartment while the engine is lowered and the hoist remains out of the way.
    The next thing to do is remove the left hand suspension strut. First remove the left wheel and the two plastic panels from the inside of the wheel well. Then I disconnected my strut at the lower ball joint, and disconnected the tie rod end. Remove the brake caliper, and wire it up so that it is not hanging on the hose. After you remove the strut completely from the wheel well you will need to wire the caliper all the way up into the top of the strut tower in order to get it out of the way. You will have to disconnect all the wires for the strut. The connector is at the forward end of the wheel well. Then remove the brake hoses from the strut. Next pop the half shaft out of the transmission. The easy way to do this is to buy a nail removal bar like you use to remove shingles from your house, the flat type that is in the shape of an “L”. Place the short end of the bar behind the CV joint, next to the trans case, put the bend of the bar on top of a transmission case bolt head, then strike the opposite end of the bar with a hammer. The CV joint should pop as the “C” clip pops out of its groove inside the transmission. Pull the bottom of the strut away from the car, make sure that you do not pull the inner CV joint out of the case by pulling on the strut, put your hand on the inner part of the inner CV joint, and pull it out of the case with your hand as you pull the strut away from the car. If you pull from the strut you will pop the joint apart, and you will have to remove the CV joint boot to put it back together. (The inner CV joint will pop apart inside the boot, the outer one will not pop apart, as they are different types) Next remove the support bar that runs between the shock towers, mark around the remaining nuts on top of the strut tower that hold the strut to the tower with a magic marker. When you put the strut back in you will be able to put it back where it was and you will not have to align the car if you mark their position. Then remove the remaining nuts from the top of the strut while someone holds the strut, it should drop out of the wheel well now. Warning it is heavy!
    Now you have to lower the engine, but first you should disconnect some wires and things before you lower it or they will get damaged. The engine will have to be lowered more on the left side of the vehicle. Disconnect the following:
    1. Pull up the boot around the joint for the steering rack connection. Remove, not just loosen the bolt that holds the universal joint to the top of the steering rack. It should pull apart as the engine is lowered.
    2. Loosen the clamp from the air filter box tube from the engine, remove the wire connector from the air filter box, remove the box from the vehicle.
    3. Disconnect the wire connectors from the temp sensors on the AC high side line that runs across the top of the firewall.
    4. Remove the plastic shroud from the relay box on the left side of the strut tower.
    5. Remove the heavy red wire that enters the relay box from below. It is a 10 mm bolt.
    6. Remove the engine computer from its mount. It is underneath the air filter box housed in a plastic shroud. It simply lifts up to be removed, it and is probably stuck on its pins pretty good. Then put the computer on top of the engine. You may have to unbolt the “L” shaped fender support just above the computer.
    7. Remove the two connectors from the transmission selector switch at the top of the transmission, aft side of the engine compartment.
    8. Take a look around and disconnect any remaining wire connectors that go from the engine to the body on the left side.
    9. Remove both upper and lower radiator hoses.
    10. Double check that everything else either has enough slack to allow for some movement, or disconnect it!
    The next step is to loosen the bottom pan of the transmission to drain the transmission fluid out.
    Now you should be ready to lower the engine. Run a chain from the front engine hoist point to the aft lift point on the left side of the engine. Attach your hoist to the chain and tension it up. Place a floor jack under the right side of the engine frame. Now you can remove the engine cradle bolts, three on each side. Start to lower the engine making sure that you are not pulling any wires as you lower it. You will need to lower the right side as well, but the left side needs to go low enough to be able to remove the transmission side pan. I recommend lowering the engine a couple of inches, then stop to check you are not pulling on any wires or hoses. Then let the engine down another couple inches. Repeat this until the side pan is visible. Once it is down low enough it is time to open up the transmission.
    You will need to mark, or make a map of the position of how all the wire clamps and studs, and bolt positions go for reassembly. Remove the bolts from the side pan. A drain pan will be required as fluid will run out as it is loosened up. The engine frame attaches to the side pan through a mount, the frame will need to be supported when you remove the mount bolts, once the bolts are out of the transmission side pan you can let the frame drop away from the transmission, it will not go too far. This will give you clearance to remove the bottom row of bolts from the pan. Now you may have to slightly bend the anti-lock brake lines up and out of the way to get clearance to remove the side pan. Once the side pan is removed you will be looking at the upper valve body, and the transmission oil pump housing. The oil pump housing sticks out the most. Remove the bolts from the pump housing, remove the oil pump, and the oil pump drive shaft. Once the oil pump is removed the remaining parts should look like this:
    There are now two remaining housings in the transmission, The upper valve body to the right, the oil pump body to the left ( the oil pump housing is gone, you already removed it) you do not need to remove them completely, they will come off with the transmission end plate if you follow these instructions. Disconnect the wires from the solenoids and the sensor on the right side. Some of the bolts that hold the pump housing, and upper valve body on have to be removed, most don’t however. The next step is to remove the bolts as shown in the next picture. These bolts pass through the end plate and enter into the transmission itself. The remaining bolts hold the pump housing and upper valve body to the end plate only, and you want to leave them alone.
    Now remove the remaining bolts that go around the end plate that are outside the transmission side pan, again, remember all the positions for the clamps, studs, and bolts. The end plate should be ready to come off now. You will have to pry a little bit to get it to come off, you should not have to pry very hard. IF YOU ARE PRYING WITH A BIG PRY BAR AND THE PLATE IS NOT MOVING THERE IS STILL A BOLT HOLDING THE PLATE ON! Find it, and remove it, the end plated is not glued down, it should come off pretty easy. After the end plate is removed your transmission should look like this:
    And the next picture is a close up of the sensor.
    The sensor and wiring harness have a wire connector at the top of the transmission. You will need to fish the wires into the same spot the old ones were at. After you install and torque the sensor and wire harness you will need to check the air gap between the sensor and the gear. This information will be found in the transmission manual you should buy.
    Reassembly of the transmission is just opposite what you have just done, with a couple of things to keep in mind.
    The end plate has two gaskets, one that goes around the perimeter of the case, and one small one that goes next to the speed sensor in the middle of the end plate, with no way to hold it as you install the end plate. You will need some kind of media to hold that gasket in place while reinstalling the end plate. Do not use grease to hold the gasket in place, the bearing type greases are high temp and will not melt into the hot transmission fluid and will wind up on your clutch plates! NOT GOOD. Use either assembly lube, or I used Vaseline. I would purchase new transmission case gaskets, they are pretty much available through GM only. The sensor is also a dealer only item.
    The only other caution I can give you is that if you decide to remove the upper valve body, there are two check balls that will fall out when you take the upper valve body off the end plate. The manual for this transmission will show you where they go on reassembly if you have taken that apart, even though there is not any need to. Then you should buy new new gaskets for that as well.
    There is the main transmission filter that plugs into the bottom of the upper valve body, I would change that as well, since you have to remove side cover to change it, now is the time!! It is not shown in any of my pictures.
    The next thing I would recommend you do is not transmission related, but now is the time to do it. Since you have the engine lowered, and the right side of the engine is pulled away from the body, and the hood is either gone or raised higher than normal, change the heater core to engine hoses!!!!! Now is the time, and by the way no time like the present to change the engine coolant, and put in new pellets!
    After the engine and transmission has been reinstalled you will need to fill the transmission, it will take almost 12 quarts!
    Good luck.
    Apr 2005
    Thanks so much. This is going to help alot. I still have to decide if I'm going to do it myself. I'm in the process of buying a house so I have no time. But with this info I would go for it. Do you know if I'm damaging the tranny by driving it this way? Thanks again....
  5. #4
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    30
    1,406
    Yes, I do believe you will cause damage to the tranny. My 2-3 accumulator spring was broken in half causing it not to shift. Ultimatly it needed a new transmission
  6. #5
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Addison, why don't you repost your writeup in the tech section so it can be referred to later. Good write up!
  7. #6
    Eldoluvr is offline Cadillac Owners Member
    Apr 2005
    30
    Great post! Sure makes me realize I cant do the job. But it also shows me I am not the only one getting that trans code and the car cab still be driven just fine with it. Sometimes the light never comes on. After fueling and long trips the light always seems to go out.
  8. #7
    Mar 2005
    DFW Texas
    30
    1,406
    Check your spark plug wires and make sure that they are not close to the wiring harness that is below them. I prefer to have them at least 3 inches from the harness. Mine fired off about half a dozen codes including the input speed sensor due to those damn wires, but sometimes it would only fire off one. I hope you get lucky, becuase that transmission is a pain in the ass to get to.
  9. #8
    black beast 96's Avatar
    black beast 96 is offline Cadillac Owners Member
    Automobile(s): 1996 eldorado
    Mar 2014
    hillsboro, oregon
    27
    34
    I'm doing this job right now, and yes I'm having trouble getting the side cover off. I've taken done just about everything you've said and then some to get it off. engine/trans are supported by chain hoist and subframe is lowered; the brake lines to the ABS modulator appear to be in the way and I've bent them just about every which way I can without damaging them. Do the brake lines need to be disconnected at the modulator?
  10. #9
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,529
    This thread has been dead for 9 years. Surf through Cadillac Tech Tips and try to find another tutorial.
  11. Remove Advertisements
