P 0300 code - 2001 Seville
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Cadillac Seville / Cadillac Eldorado Forum Discussion, P 0300 code - 2001 Seville in Past Cadillac Vehicle Discussion; Hi everyone , 2001 caddy Seville SLS , 4.6 NORTHSTAR , 115000 MILES. driving from a stop position , I ...
    timman is offline Cadillac Owners Fanatic
    Automobile(s): 1996 cadillac deville
    Jun 2010
    106
    Hi everyone , 2001 caddy Seville SLS , 4.6 NORTHSTAR , 115000 MILES. driving from a stop position , I suddenly get a "flashing" service engine soon. I pull over and have a "rotten egg / sulfer" type of smell coming from car. I pull code P0300 (engine misfire / mis fires). very rough idle now. checked injector fuses (ok) , and any disconnected vacuum hoses, couldn't find anything out of the ordinary. I guess it could be a number of things , but I am thinking of cat converter ???? now it has a steady "service engine soon", not flashing. Any help ????? Thank You , Tim
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Re: p0300 code
    P0300 is a generic misfire code. Take it to Advance or AutoZone and have them scan it, they should be able to give you the code(s) for the cylinder(s) misfiring. The reason your smelling the rotten egg smell is because raw fuel was dumped into the exhaust system as it didn't get burned up in the cylinder due to the misfire(s). Once you get the code you can narrow down your search a bit more, could be spark plug(s) or one of the coil cassettes may have failed. If you keep driving it though you risk damaging the catalytic converter.
    69
    82,180
    Re: p0300 code
    Curt is correct. The sulfur smell is from running rich. Check for a leaky FPR.
    Jun 2010
    106
    Re: p0300 code
    pulled code P0308 , cylinder 8 misfiring. does anyone know what plug I can pull to check first. I will be looking at the engine from front of car. Thanks , Tim FPR ??? Fuel pressure regulator ???
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    Re: p0300 code
    Pretty sure cylinder 8 is on the front bank to the far right if you're looking at the motor from the front of the car. Yes, FPR is fuel pressure regulator. If the injector is working it is more than likely a bad plug or coil cassette. I see you mentioned you're at 115k, 100k is the recommended mileage to change them so if you don't know the last time they were done I would just change them all.
    69
    82,180
    Re: p0300 code
    Firewall
    1-3-5-7
    2-4-6-8
    Front of car
    Jun 2010
    106
    Re: p0300 code
    yes it is on the far right facing motor. anyway I tried a new spark plug , but no go. I am thinking the coil pack ????? Thanks , Tim
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    Re: p0300 code
    Many, many ignition parts pictures for that 2001 engine in my albums - the Community tab ^^^, Albums, the red Seville.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by timman View Post
    They're interchangeable so you could test by swapping the two. If the miss follows you've found your culprit. If it is the coil I suggest used, new ones are way over priced.
    69
    82,180
    Re: P 0300 code - 2001 Seville
    Could be a plug, plug wire, coil or ICM. How old are the plugs & wires?
    Jun 2010
    106
    It ended up being the coil pack. I replaced it with a new one from adv auto (20% off using code P20 or CC20). Thank You everyone for all the help.....I appreciate it very much !! Tim
    69
    82,180
    What's a "coil pack"? You have 4 coils mounted on the ICM. Do you mean all 4 coils?
    Feb 2006
    56,606
    The first post says he's working on a 2001 Seville - but his login banner says 1998 Deville.
    tinman, If you have changed cars, please update your profile. Thanks .......
  16. #14
    69
    82,180
    Even on an '01 there is no such thing. I know I'm being picky, but I just hate these inaccurate terms.
  17. #15
    Feb 2006
    56,606
    Yeah ......... The GM service manual (some of them) refer to the assembly as a "cassette"; other manuals and sites refer to them as "ignition coil", "coil assembly" or any of another half dozen names.
    I usually use the "cassette" for 2000 - 2003/4, "coil" for the 4-coils on the ICM (waste spark) pre-2000 setups, and "coil assembly" for the later 4 coils on one bar (the newer coil-on-plug setup).
    For instance .............
  18. Remove Advertisements
