1995 eldorado bottomed out hard and stopped running.
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1995 eldorado bottomed out hard and stopped running. in Past Cadillac Vehicle Discussion; i bottomed out my eldo hard and it quit running . fuel pump runs it, turns over but will not ...
    obiwan is offline Cadillac Owners Member
    Automobile(s): 1995 eldorado
    Oct 2013
    4
    i bottomed out my eldo hard and it quit running . fuel pump runs it, turns over but will not start. any ideas?
    68
    81,731
    Re: 1995 eldorado bottomed out hard and stopped running.
    I'll bet there is a good story behind this.
    Have you pulled the DTC's? Have you checked the fuses?
    Oct 2013
    4
    coming out of my club i went over a rock and bottomed out. i checked some fuses that i could get to need to pull a big cover to gert to larger ones.. dtc's ..codes?
  5. #4
    68
    81,731
    Yes, DTC = Diagnostic Trouble Codes.
  6. #5
    Oct 2013
    4
    history codes po52p109po15,so44
    currentao11,ao47,sd38
  7. #6
    68
    81,731
    Codes are meaningless without their definitions. No one has them memorized. See the DTC Sticky for a link. You want the OBDI link.
  8. #7
    Oct 2013
    4
    didn' see anything other than air cond, pcm, and level sensors. gonna jack it up and see if i can see anything. any thoughts?
  9. #8
    The Gold's Avatar
    The Gold is offline Cadillac Owners Fanatic
    Automobile(s): 92 El Dorado
    Jul 2010
    San Francisco
    125
    Does it have a trans selector switch that allow/disallows engine start up? Maybe its wire harness came loose or coincidentally was going south.
  10. Remove Advertisements
