Another stalling Seville.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Cadillac Seville / Cadillac Eldorado Forum Discussion, Another stalling Seville. in Past Cadillac Vehicle Discussion; Been a while since I've had to post about my Caddy acting up(thank the car gods), but she is getting ...
    BAM19040 is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Seville SLS
    Apr 2011
    Wisconsin
    26
    29
    Been a while since I've had to post about my Caddy acting up(thank the car gods), but she is getting moody again. Thanks to the forums I replaced my burnt out starter with ease last week and now she fires right up. But now she is stalling at red lights and today it stalled for the first time while decelerating to a stop. It was doing this prior to me changing out the starter but it has only started doing this maybe 5 thousand miles ago? It does not do it all the time, maybe once or twice a day, and I do almost all stop and go driving. At first it wouldn't throw any codes but today, I got some! And they are...
    DTC P1599 Engine Stall or Near Stall Detected
    DTC P1520 Transmission Range Switch Circuit
    DTC P1350 Ignition Control System
    DTC P1375 IC 24X Reference Circuit High Voltage
    Another thing I noticed it took it 2-3 cranks before it started back up after stalling while idling in my driveway for about 1-2 minutes, and it was kind of a sluggish fire up and I had no movement of the tac needle until I restarted it.
    I have very recently put new plugs(delcos, but I did not get new wires. It had bosche's in when I bought it and they needed to go), cleaned out the TB, EGR, IAC, and checked the vacuum lines.
    Have not checked fuel pressure during stall but FPR is dry when I pull off the line. Have not checked fuel filter either.
    Voltage stays steady above 14v during stall.
    I'm just wondering whats next? Crank sensors? Cam sensors? Coils? Wires?
    Thanks in advance.
    deleee is offline Cadillac Owners Member
    Automobile(s): 93 Seville
    May 2013
    8
    Re: Another stalling Seville.
    Hi, I have a 93 Seville SLS. I think this sounds similar to my problem. She was throwing Voltage too high code. some times INFL REST (air bag light) and every once in a while stop for no reason. I figured it must be electrical. Well I over looked the obvious. Does it seem to happen when your gas is low? Turned out to be my fuel pump.(some wires are there too) I got it changed and al the lights and bells stopped but the car doesn't !
    Well, the INFL REST light returned. Doesn't stall though. Guess I need to check the electrical after all.
    Apr 2011
    Wisconsin
    26
    29
    I had just under half a tank in it today when it was doing it. I also had bad/weak fuel pump in my head, but im praying not. I do have a bad habit of running it low before I fill it back up..I also have an airbag code pertaining to the passanger side pre-tensioner. I never would have thought that would be connected to this in any way..?
    68
    82,048
    It's possible you have a failing CKP senor. They don't always set a DTC, but the pre-2000's are not known for failures like the 2000+'s. Based on those P1375 &P1350 codes I would suspect a bad ICM.
    See the ICM Sticky in the Northstar forum for more info on how it works.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,649
    Did you make sure the ICM ground was on under the coil packs when you changed the plugs in the rear bank?
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    Had the same codes (1350 and 1375) when my ckp's were bad. Also thought of icm first, turned out not to be that... So most likely ckp imho. Might also come with rev meter not working...
    Apr 2011
    Wisconsin
    26
    29
    It seems to be doing it more often the pass couple days. I think I'm going to throw crank sensors in it tomorrow and pray that helps. Should I replace both of them? And what's the easiest way to get to them?
    Jul 2012
    38
    140
    Replacing both is recommended, with ac delco ones. You'll have to remove the oil cooler, have some new o rings at hand... Pretty straight forward job, just not much space... Good luck
    68
    82,048
    Always do both. I got both of mine from Amazon for about $77 incl shipping.
    There is no easy way. Drop the lower air deflector. Then remove the oil filter adapter. Then the CKP sensors are a bit more accessible, but it's still a tight fit. You'll need a long extension and a universal joint.
    There should be at least one tutorial in the Tech Tips section.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Grr. Kids grand prix had tach drop to zero. Motor is running ok for now. Turns out gp 3.8 also has rare crank sensor issue too. And u need to remove balancer to change sensor.
    Apr 2011
    Wisconsin
    26
    29
    No good. My caddy runs like a dream minus this stalling bulltucky I'm dealing with. Short story, I started a new job last night and my car stalled while pulling IN to the parking lot. I crank it back up and literally drive 50 ft. through the lot and it stalls again as I'm coasting towards a spot to park. Two stalls within the length of a McDonalds drive through, right in front of all the new people I'm about to meet. Good first impression huh? I ordered the sensors so I'm waiting on those to arrive and I'm then I'm going to tackle the job. I'll report back when the job is done with some hopefully positive news. Might take me a while though, Wisconsin is gettin' chilly and I hate working on cars when it's cold. Hell, we're expecting snow next week! I need to invest in a heated garage. Thanks again for the help everyone.
    Aug 2007
    mpls mn
    2,528
    ANY garage is nice in winter.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    ^^Why?^^
  16. #14
    Apr 2011
    Wisconsin
    26
    29
    Just an update. I have the sensors but I have not changed them yet. I park my caddy for winter so I planned on doing it once the snow fell. I'm still stalling every now and then, but I've grown to rev it up a little at stops so it doesn't die. I got on the gas a little bit today and P0101 code popped up and my car started running like crap. That code is a MAF code. Could that have been the problem all along? Like I said I have cleaned everything spotlessly and am still stalling and now getting the MAF code. Do I get a new MAF and hold off on the CKPs to see if that stops the stalling? I can reset the codes and it runs like a champ again until I rev it up pass 5k rpms and the MAF code pops.
  17. #15
    68
    82,048
    A bad MAF sensor can cause a stall I believe.
    I don't know how you can rev it to 5K when the rev limiter is set to 4K.
  18. Remove Advertisements
