how do i take the govern off?? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
Cadillac Seville / Cadillac Eldorado Forum Discussion, how do i take the govern off?? in Past Cadillac Vehicle Discussion; Thanks, last I checked with Hypertech, they didn't have anything, but it's been a while....
  1. #16
    Randy_W is offline Banned
    Mar 2004
    1,063
    Re: how do i take the govern off??
  2. #17
    jgwlex is offline Cadillac Owners Member
    Jan 2005
    Lexington, Kentucky
    33
    25
    Quote Originally Posted by mysts98
    after hearing all this ill just keep my car governed.......anyone on here now where i can get hid;s for my car????
    I bought a set of McCulloch HIDs on eBay. It's as close to the factory HIDs as you are gonna get for a fraction of the cost. I paid $280, and it really is an easy install. It is no comparison to halogen bulbs or silverstars.
  3. #18
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    There is absoultly no programer available for the 96+ northstars yet. There isnt a market really for them like there is for Vettes and FBodys, hence why Katshot lucked out his FTS has an LT1 like a vette so they make programers and chips.
  5. #19
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    The only way a dealer COULD do this is if you did a mound of paperwork, and they called GM, an engineer would have to rewrite a calibration, send it to the dealer and the dealer could then re-program the car.
    This process ends up being something called calibration by a VCI number.
    It also costs about 200 dollars to get them to issue a VCI calibration out of warranty. Basically don't look to GM to get this done.
  6. #20
    Odin8 is offline Cadillac Owners Fanatic
    Automobile(s): 97 STS (retired), 05 STS4 (retired), 2013 CTS V coupe
    Nov 2004
    Central Massachusetts
    30
    218
    Quote Originally Posted by 91TexasSeville
    Not likely, as the STS/ETC with the 150 MPH option and Z rated tires also has different vehicle ID, and different emissions from the non Z rated vehicle.
    Different emissions requirements just becase of a higher govenor? That doesn't make sense to me...
  7. #21
    91TexasSeville's Avatar
    91TexasSeville is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX-V8, 1991 Eldorado
    Oct 2004
    Near Houston
    66
    1,543
    Yup...
    The tune is different, so then is the standard.
  8. #22
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    alright I need to figure this out....my '95 sts is z-rated and it tops out around 132-134 or so, and almost everyone else says it should go 150, why is this?
  9. #23
    WarrenJ's Avatar
    WarrenJ is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 ETC Sequoia
    Apr 2004
    Long Island, USA
    878
    Quote Originally Posted by curtc
    Was your PCM ever changed out?
  10. #24
    kevinrea is offline Cadillac Owners Fanatic
    Aug 2005
    166
    Hey KATSHOT ..
    so, where do i find one of these aftermarket reprogrammers willing to reprogram my car's brain ?
    i haven't been able to find any myself.
    i sure would like to know of a few.
    kevin
    kevinrea@adelphia.net
  11. #25
    Oct 2005
    15,987
    there is NO PROGRAMMER
    ZERO
    NONE
    NON EXISTANT
    FOR THE 4.6 Cadillac Northstar
  12. #26
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    32
    3,703
    There is absolutely no way that the emissions requirements for the H and Z rated cars are different. That wouldn't be very cost efficient. Plus, at 130mph, your still only getting maybe 8mpg. Emissions don't come into play at those speeds. The EGR system isn't working, plus the engine is literally dumping fuel in the engine to keep the pistons cool. To re-engineer the emmissions system for a limited amount of cars would cost an exuberant amount of money. GM has been known to do dumb things, but even that's pushing it. The only difference between the two is the governor. All the programming for how the governor works is in the Z rated PCM. It's works very similar to the T/C system, in how it can control Fuel, and Ignition timing to limit engine power. All they have to do is either add that simple line of code in there, and you've got a governor. Removed it, and the governor is gone.
  13. #27
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    I got 140 on the dial from my STS, no cut off or anything .
    "I" cut it back.
    A guy that was very reputable said that Z rated cars were NOT GOVERNED, and that these cars were limited to only the limits of the engine and the extent of the performance and the end of the envelope of the engine itself.
    Over all meaning a potential melt down and critical breakdown of the drivetrain due to over extremism.
    Ie: a true blown engine.
    And things bad all around.
  14. #28
    STS 310's Avatar
    Dec 2003
    LOS ANGELES CA
    1,489
    Funny thing is the PCM reads the MPH different on a different cars give or take a few MPH. It SHOUD NOT HAVE A CUT OFF.
    Are you sure you are at those speeds?
    PLEASE DO NOT GO OUT AND TEST THIS THEORY IF YOUR SPEEDO SAYS 134 and your fuel cut off says "Fuel cut off" or "max speed reached"
    IF I AM WRONG AND THERE IS A CUT OFF/GOVERNER, Please adhere to the DIC and SLOW DOWN!!!!!!!(YOU WILL HAVE NO CHOICE ANY WAYS, BUT DONT TRY IT IF YOU ARE NOT Z RATED WITH Z RATED TIRES).
    ONLY Z RATED AUTOS WERE MEANT TO BE PUSHED TO AUTOBAHN SPEEDS.
  15. #29
    Oct 2005
    15,987
    i love my Z rated ETC she keeps going and going and going then the motor will really blow lol a fitting end rather than some b/s headgasket failure
  16. #30
    Caddysodry is offline Cadillac Owners Member
    Feb 2004
    11
    Is there anything else thats different from the Z rated STS/ETC to the non Z rated cars other than tires , programing and emissions ? What year did they start with the Z rated version.
  17. Remove Advertisements
