92' STS no crank problem
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, 92' STS no crank problem in Past Cadillac Vehicle Discussion; I have a STS that has been setting all summer and today when I went to start it the battery ...
    wk4036 is offline Cadillac Owners Member
    Automobile(s): 92 Seville STS
    Jan 2006
    SW Michigan
    52
    9
    I have a STS that has been setting all summer and today when I went to start it the battery was dead so I put the charger on it for most of the day and when I went to start it the normal lights come on in the instrument cluster doing the tests but it won't crank. Another thing I noticed is that nothing shows in the information window and the bottom of the cluster.
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Re: 92' STS no crank problem
    Try a new battery.
    68
    81,938
    What is the voltage both static and while attempting to crank? Chances are you have a dead cell.
    Jan 2006
    SW Michigan
    52
    9
    I will try a know good battery and report back
    Jan 2006
    SW Michigan
    52
    9
    Well I put the tester on the battery and it shows 13 volts static and while turning the key to start, the dash lights dim while turning the key but there is no voltage going to the small wire that engages the starter solenoid.
    68
    81,938
    Not sure about the dash lights, but if the headlamps dim, it probably is a dead cell.
    Are you saying you have zero voltage while cranking? You should still have about 9 or 10 with 1 dead cell.
    Jan 2006
    SW Michigan
    52
    9
    The voltmeter at the battery hardly moves when key is turned to start position but dash lights dim, also checked the smaller wire at the started solenoid that actuates the solenoid and there is no voltage when the key is turned to the start position.
    68
    81,938
    Sounds like it might be a bad starter switch (not the lock cylinder) down on the column.
    RetiredSFC 97 is offline Cadillac Owners Member
    Automobile(s): 1999 STS
    Feb 2013
    Columbia, Mo
    56
    Well, what happened? Any progress? In my opinion it's the battery or the starter and/or wires to starter. I can't count the number of batteries I've had that tested good and they were bad. Went through it this past winter with my tractor. It made me mad trying to find the problem until I said the heck with it and went and bought a new battery. Solved it. What made it worse was I had some mice chew up some wires around the instrument cluster so who wouldn't think that's where the problem was? I changed that out and still no dice. Then bought a new battery.
    I just had this same issue on my Dodge Pick up. Oreilly said the batt was good and didn't want to honor a warranty I had on the battery. I took them the pick up and they tested the alt and it was good so they reluctantly honored the warranty. Problem solved.
    Your car didn't die all on it's own just from sitting. It's a starter or batt issue, or both, or a wire somewhere that got chewed up by a mouse is my opinion.
    Jan 2006
    SW Michigan
    52
    9
    Well I finally got a chance to fiddle with it again and put my remote starter button on the starter and also found out that even though a battery checks good it may not be so I put a new battery in it and it will crank with the remote button and start for about 2 seconds and then die and if I turn the key off and back to run it will run for about 2 seconds and die again but that is all the time I had to spend on it.
    68
    81,938
    Have you checked your fuel pressure?
  14. Remove Advertisements
