Fuel gauge problem - 2001 Seville
Results 1 to 15 of 15
Cadillac Seville / Cadillac Eldorado Forum Discussion, Fuel gauge problem - 2001 Seville in Past Cadillac Vehicle Discussion; Hi, I just recently purchased a 2001 Cadillac Seville and not much is wrong with it. One of the problems ...
    robfitzgibbon is offline Cadillac Owners Member
    Automobile(s): 2001 Seville
    Oct 2013
    23
    5
    UnhappyFuel gauge problem - 2001 Seville
    Hi, I just recently purchased a 2001 Cadillac Seville and not much is wrong with it. One of the problems though is that the fuel gauge does read at all. It never moves and it's always on E. So it makes me think that the fuel sending unit is possibly not the problem. Everybody Else's posts about having a fuel gauge problem indicate that theirs jumps up and down. I have gone through the error codes and I have a PCM P0463 which indicates a High Fuel Level Sensor Voltage if I'm correct? What i'm thinking is a wire rusted out somewhere but I have no idea where to look for it..? Can anybody help me out?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: Fuel gauge problem - 2001 Seville
    Your car has a fuel pump module access hatch in the trunk floor - right forward of the spare tire well. Under that hatch is the top of the entire pump module with the fuel lines (quick connects), electrical connector (4 pin - pump and fuel level sender), and tank pressure sensor.
    Pictures of the module in my albums - click my username, open the profile. Left column - 2 albums, 6 pages of stuff for your car.
    Study the Cadillac Technical Archive way up ^^^ in the top black bar. Read each sticky in forums of interest.
    Welcome Aboard !!!
    Oct 2013
    23
    5
    Thanks for the reply Submarniner! I've gotten to where you're talking about, although I don't see any problems with the wires at first glance..should I try and take them out and plug them back in? I'm scared if I unplug them my fuel pump will stop working, sorry I'm far from a mechanic :P
    And will do! I've been reading up on it now but have some more to go. Thanks a lot!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The fuel pump isn't going to fail from unplugging it. You'll just be unplugging an electric motor that's turned off.
    That said, unless there's just some light corrosion on the pins, disconnecting and reconnecting it isn't going to help.
    68
    81,917
    You're in for a new sending unit. May as well just put a whole new assembly in while you're there.
    Oct 2013
    23
    5
    Ok thank you guys! That's really what I wasn't hoping for but it is what it is...At least everything will be up and running after. I'll let you guys know how it goes when I get the new parts in!
    Sep 2010
    East Boston MA.
    29
    26,325
    It's not that bad of a job, since you don't have to drop the tank.
    Feb 2006
    55,891
    ........... and there are How-tos and pictures in the pages of Cadillac Tech Tips - down in Discussions, Item Specific.
    Oct 2013
    23
    5
    I will definitely be looking at them when I do it! I just don't have the money at this moment in time, I have to wait until payday and I'll be buying the whole assembly.
    Another question though, the catalytic converter was stolen on it I guess (before I purchased the car), and it releases these terrible fumes into my car. Carbon Monoxide, so I know I have to do something quick about it. Until I purchase a new converter, do you think maybe putting a straight pipe on there would help with the fumes? I know you're not supposed to legally do that and I know it's not good for the car, but something has to be done about the fumes until I get it fixed... What's the best route I could go with this?
    Sep 2010
    East Boston MA.
    29
    26,325
    The converter has nothing to do with carbon monoxide. But wait, if there's no cat, and no straight pipe, are you just running a totally open exhaust??
    Oct 2013
    23
    5
    Hmm, I had always thought it was on there to help convert Carbon Monoxide to Carbon Dioxide? And I'm not sure to be honest, like I said I'm not much of a car person at all. So I'm going to take a picture of it, and upload it on here for you guys to look at...
    Edit: So I can't get any pictures because I can't get a hold of my buddy to use his jack at this second, so basically what it looks like is the pipe comes down from the engine or whatever, goes down to about the middle of the car right about underneath the rear seats and then connects to a roundish looking bigger pipe (which I'm guessing is a shield or the converter, which is strange because he said it was stolen) and then comes out the back of that and then splits into the two exhausts ends. I'm gonna read through all the pictures and see what it's supposed to look like and let you know..
    Sep 2010
    East Boston MA.
    29
    26,325
    If it was open exhaust, you'd know it, it would be LOUD!
    With the converter removed, the CEL should be illuminated.
    The larger pipe you're seeing is probably the resonator.
    Feb 2006
    55,891
    Diagrams of your exhaust system (aftermarket) parts in Rock Auto. Original in the proper year/model, system/text page - click the More Info tab for the diagram in www.gmpartsgiant.com.
    Front Y-pipe flange, flex coupling, cat, resonator, exhaust pipe, Y, mufflers, tips.
  16. #14
    68
    81,917
    My guess is that the converter was removed vs stolen. Either way, unless the exhaust terminates under the car vs at the rear, you should not be smelling anything, CAT or no CAT. If you are smelling exhaust fumes, you may have a leak.
    P.S.
    The CAT does not convert carbon monoxide to carbon dioxide. "It reduces tailpipe emissions of hydrocarbons (HC) and carbon monoxide (CO) to extremely low levels".
  17. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    Well without the car, there will be a stronger exhaust odor. But carbon monoxide is odorless, that's not what you're smelling. Sulfur is what most people smell most.
  18. Remove Advertisements
