disp mode light out
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, disp mode light out in Past Cadillac Vehicle Discussion; I have my dash pad out and see it is a good time to fix this light out that has ...
    accuab's Avatar
    accuab is offline Cadillac Owners Member
    Automobile(s): 2002 Seville SLS
    Sep 2013
    30
    88
    disp mode light out
    I have my dash pad out and see it is a good time to fix this light out that has been bothering me. Does anyone know if this is an led or a "grain of rice" bulb in the disp mode button. And should I just go ahead and redo all 6 buttons while I'm there. I know it's smarter to go ahead and do all 6 but haven't pulled the button yet and not sure how hard it will be to open it up without breaking it any in the process. I've done this before in several vehicles but not this one. They were all gm vehicles so I'm sure it is similar. I'm thinking in the past that I just put an led with a resistor in place of the light bulb but I don't want the brightness or color to be different.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: disp mode light out
    Quote Originally Posted by accuab View Post
    Cadillac calls this a NON-SERVICEABLE light - and will only sell the entire switch -
    but here it is - Attachment 149969
    YES -
    68
    82,064
    Bass, are you sure those buttons use a bulb THAT big. After doing the seat heater buttons on the console and the 6 steering wheel buttons (smaller yet), that thing looks like a street lamp.
    accuab's Avatar
    Sep 2013
    30
    88
    I've seen some tiny bulbs like that in a base. I believe I actually still have some around that size from a grand prix from years ago. I searched everywhere and finally just pulled some for free at a junk yard. If I could find a small enough bulb with long enough leads, I could just transfer them into the base. Also what is required to pull the bezel from the instrument cluster or can I just remove the buttons from it while it is in place?
    68
    82,064
    Pretty sure you need to remove some dash trim, but without a FSM I'm not sure how.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    yep - gotta pull the dash pad first -
    HA HA - they do look big - but these are the correct ones -
    68
    82,064
    They ARE big compared to the micro surgery required for the ones I just did.
    accuab's Avatar
    Sep 2013
    30
    88
    Basscat, does that honda bulb fit it perfectly? I found them online by the part number in your picture. I was gonna buy some bulbs from radio shack and just put them in the base if needed. I had some bulbs that are almost exactly like these but the bulb is just slightly larger and will not fit in the hole like I thought they would.
    accuab's Avatar
    Sep 2013
    30
    88
    Quote Originally Posted by basscatt View Post
    YES -
    Does that bulb fit it perfectly? I wanna go ahead and order them but wanted to make sure they were the right ones.
    accuab's Avatar
    Sep 2013
    30
    88
    I'm needing to do the steering wheel control lights and saw on another post to use some bulbs from radio shack. Do y'all think these would work for the icp buttons as well? I know I would need to transfer them into the plastic base that matches up to the icp. I don't have a digital micrometer to actually measure the size of the bulb that is used in those buttons to verify if it will work. I'm having to order the bulbs because apparently the town I live in is too small to keep the radio shack we had so they closed it down and I don't go anywhere near one on a frequent basis. Here are the bulbs I'm referring to :
    http://www.radioshack.com/product/in...ductId=2103780
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    if memory serves me right - those bulbs are too big to fit into the plastic mount -
    68
    82,064
    The bulb in that link is correct for the steering wheel button light, but I'm not sure what an "ICP" button is.
    They look huge in the picture in the link. Here is a better perspective.
    accuab's Avatar
    Sep 2013
    30
    88
    By icp button I meant the buttons to the left and right of instrument panel. I used a caliper and measured to bulb in it and compared the numbers to the radio shack bulb. The rs bulb is a half a mm thinner and a mm longer so I'm thinking it will work.
  16. Remove Advertisements
