92 Eldo brake job caliper C clamp size...
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac Seville / Cadillac Eldorado Forum Discussion, 92 Eldo brake job caliper C clamp size... in Past Cadillac Vehicle Discussion; What size C clamp do I need to compress the piston on the front caliper? And for future reference, I ...
    pocketpared is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Eldorado
    May 2009
    200
    What size C clamp do I need to compress the piston on the front caliper? And for future reference, I assume the rear caliper would be the same, correct?
    Thanks.
    69
    82,386
    Re: 92 Eldo brake job caliper C clamp size...
    You need a big one, though I'm not sure of the exact size. This should give you an idea.
    The rears are different. They screw in. You need a brake piston cube.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    You know, I've never used a C clamp ever. I jamb a large flat head screw driver between the pad and rotor and slowly pry the pad back. Then I remove the caliper. Yes you will need the cube! on the rears.
    May 2009
    200
    Thanks for the info. I read 9" clamp from an unreliable source. Guess I'll opt for that and grab a cube for future use.
    69
    82,386
    9" sounds about right.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    like carnut - I too - never used a C-clamp -
    I always used the big flat-blade screwdriver to "start" retracting the piston -
    then finished it with a large channel-lock pliers -
    May 2009
    200
    Thanks. How long should it take to retract the piston? I know to open the brake fluid reservoir. It's a slow process but I read it should take 15 - 20 minutes. That does sound excessive.
    Feb 2003
    california
    69
    6,689
    Assuming the reservoir is not full, I just pry till it bottoms out in the caliper. Maybe 30 seconds. I never open anything.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    Quote Originally Posted by carnut View Post
    May 2009
    200
    69
    82,386
    Are you talking about the front or rear? The rears with that cube will take a bit longer, but not 15-20 min.
    P.S.
    The rears are easier if you open the bleeder valve.
    May 2009
    200
    Fronts.
    69
    82,386
    30 seconds would be a long time to compress the fronts.
  16. #14
    May 2009
    200
    Okay. Thanks. When I do the rears though (not for a long time), I can do it without opening the bleeder valve? Maybe that's what I read where it took a long time, especially with the cube. I'll be doing this in my small garage so I'd like to keep it as simple as possible.
  17. #15
    69
    82,386
    Yeah, you do not have to open the bleeder. The cube tends to slip off the piston and you are pushing fluid all the way back through the entire length of brake pipe so it makes it a bit harder. Just one of those tricks to keep in mind should you need it.
  18. Remove Advertisements
