Vroom Vroom... 2001 STS, CORSA, Dyno run - Page 4
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 118
Like Tree44Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Vroom Vroom... 2001 STS, CORSA, Dyno run in Past Cadillac Vehicle Discussion; Give me a little while to get the pics uploaded. I just got in. It's more than "just a few" ...
  1. #46
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's more than "just a few" at redline.
  2. #47
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,253
    Re: Vroom Vroom...
    How about 16 to 20 ???
    This is the old CORSA graph from an earlier advertising site - 'twill be interesting to compare.
  3. #48
    Sep 2010
    East Boston MA.
    29
    26,325
    Sorry for the delay! One of my fathers tennants had a problem with their stove, which is gas on gas, so also the heat for the apartment. I had to go fix it.
    Sub, my peak numbers were a bit higher, but 16 was the number.
    Stock:
    213.1 HP @ 5,100 RPM
    242.3 TQ @ 4,200 RPM
    Corsa:
    229.1 HP @ 5,100 RPM
    249.6 TQ @ 4,650 RPM
    They did 2 runs before and after, both times the second run was the better one.
    +16 HP
    +7.3 LB-FT of torque
    It sounds REALLY good. It's quieter at lower RPMs than I was expecting. Drone is absolutely ZERO.
    JoeTahoe likes this.
  5. #49
    Feb 2006
    56,253
    Re: Vroom Vroom...
    MC, Just logged on. Thanks for the work and the post. Not much gray area there ..............
  6. #50
    Sep 2010
    East Boston MA.
    29
    26,325
    I figured the $150 spent on the dyno was worth knowing once and for all what the system could do. I wasn't expecting more than 5 or 6 at best.
    It's also nice to see that my car still makes the same power as a much newer one. Any idea when Corsa dyno'd the system?
    Edit:
    Oh, never mind. I see it was done in '01 with an '00. Not bad for a 12 year old car that's just hit 90K .
  7. #51
    Feb 2006
    56,253
    Re: Vroom Vroom...
    Hard to believe that straight pipe with resonator/muffler casing wrapped/welded around it can sound that quiet most of the time and break your eardrums at WOT.
    If you do a WOT through 1st to 2nd redline and flip your foot off the gas you'll hear the POP as the fuel injectors turn off during the forced deceleration.
  8. #52
    Sep 2010
    East Boston MA.
    29
    26,325
    Soooo from a happy ending to the usual BS I deal with. Took a ride earlier, went over a tiny hump in the road, and hear a loud,metallic slap against the road. I get out, look under, and the resonator is a few inches lower than it should be.....
    I drive to my regular exhaust shop, we put it on the lift, and guess what... The mid pipe is on UPSIDE DOWN! Which means the whole system tapers down from the rear because the hanger bar on the mid section is on the top instead of the bottom (the hangers WERE attached, but were just being pushed upwards and not supporting any weight).
    I took a few pictures, and immediately took it back to the shop that installed it. I showed him the picture, and he outright refused that he installed it wrong. I told him I was going to call Corsa. While I was on the phone, he walks back out of the shop, says "Aaron, you're right, I "F'd" up". He read the instructions that he still had, and saw that it was in fact upside down. He told me to pull it right onto the lift of the Meineke next door, and he'd fix it right away. I said fine, but we'd have to talk about replacing the resonator afterward. He said ok.
    I stayed out front and watched for a while, then went into the waiting room for a few minutes. Then I hear a SAWZALL!!! I run out into the shop, and he's 3/4 the way through the pipe..... WARRANTY VOID!!!
    He was apparently trying to get the system to sit further back.
    I was ready to snap his neck, but kept calm. I asked what we were going to do about the problem, and he just went off, yelling, swearing, insulting me.....
    I told him to bolt everything back on, and get it off the lift. Once it was off, I inspected it. The tips are all scratched up on both sides. What a complete disaster...
    Long story short, I'm taking them to small claims court for the price of a new system.
    Why didn't I notice the upside down pipe in the first place? Because I couldn't go into the shop for insurance purposes, and they only let me peek briefly when it was done. I talked to 3 different shops about exactly what I wanted done, and exactly how I wanted it done, before deciding on this one. They assured me it would be done to my standards. As usual for me, SO MUCH FOR THAT!
  9. #53
    Feb 2006
    56,253
    Re: Vroom Vroom...
    I still have the install sheets for my system. If a shop could not follow the simple instructions and do it correctly, they NEED to be hauled into small claims - but $1,000 + labor is not "small".
    I would be ummm...... angry. Ask the installer if he read the yellow paragraph on the first page ...........
    http://www.corsaperformance.com/medi...50/INS5011.pdf
  10. #54
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: Vroom Vroom...
    You and i got to be related. You have the same bad luck i do. hell i was born on fri 13th of October and had my nose sliced when they did the c-section on my mom to get me out.
  11. #55
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    When you win the court case can I call first dibs on your old Corse system?
  12. #56
    Sep 2010
    East Boston MA.
    29
    26,325
    Sure, I'll sell it.
    .....I just don't get why I always run into incompetent morons EVERYWHERE, no matter how much research and/or planning I do.
  13. #57
    Sep 2008
    29
    675
    Awesome, its new life will be a '93 4.9 Seville
    Out of every forum I'm on you seriously have the worst luck of anyone I've read about. I wouldn't even recommend buying a lotto ticket surely you'll win but what would happen on your way to cash it?...
    Lifer and MoistCabbage like this.
  14. #58
    Feb 2006
    56,253
    Re: Vroom Vroom...
    Most of the #14150 CORSA will not come anywhere remotely close to fitting a '93 anything.
  15. #59
    Sep 2008
    29
    675
    I'm fairly aware I'm most interested in the Y and after section, the rest can be fabbed by my guy. Won't be as pretty but I am very interested to hear how the 4.9 will sound.
  16. #60
    Sep 2010
    East Boston MA.
    29
    26,325
    Reported to the BBB and review posted on Yelp.
  17. Remove Advertisements
