Pulsing Lights
Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By Ranger
  • 1 Post By Submariner409
  • 1 Post By basscatt
  • 1 Post By Playdrv4me
Cadillac Seville / Cadillac Eldorado Forum Discussion, Pulsing Lights in Past Cadillac Vehicle Discussion; 1. I have a 94 Eldorado with 64K miles. I have had it for 3 years now and have noticed ...
    Northstarnut's Avatar
    Northstarnut is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Oct 2013
    Granite Falls, WA
    64
    20
    Pulsing Lights
    1. I have a 94 Eldorado with 64K miles. I have had it for 3 years now and have noticed that the lights are flickering (pulsing). It affects all lights, dash, headlights, dome lights etc. I have a new battery, and the charging states 14.2 volts on the display. It is annoying to say the least, but I also think this pulsing will affect the longevity of the bulbs. Has anyone else experienced this weird phenomenon?
    2. Does the 94 have a cabin filter and if so, where is it located and how can I change it?
    3. I know the previous owner changed the trans filter at about 35K. At about what point should I change it again?
    4. I need to service the ride control according to the display, but the air rides seem to be working and the ride height is level and stable. Is his just precautionary or is there something I need to be concerned with?
    5. How involved is it to change the pads and rotors on the front? They are spongy and vibrate on stops.
    I am new to the forum and look forward to your responses. Anything else I should look into or be concerned about?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by Northstarnut
    It's a problem with the voltage regulator in the alternator.
    The Eldorado never got a cabin air filter. Don't worry, they're pretty pointless anyway.
    The filter is only accessible during a rebuild. There are 2 cleanable screens accessible with a pan drop. If you want, you could switch to the new Dexron VI transmission fluid.
    The message means that a C code has been set. I assume this is an ETC? There's a problem with the active suspension system. You'll have to pull your codes to find out what. Go to the top of the Eldorado/Seville page, and read the "sticky" thread on How To Pull DTCs. List any codes you find, AND TGEIR DEFINITIONS, here (there's a link within the sticky with code definitions).
    Same as any other disk brake job. Remove caliper, pull off rotor, install new rotor, remove pads, push in piston, grease back of pads, install new pads, reinstall caliper.
    If you've done it before, you're all set. If you haven't, ask more questions here, have someone who has help you, or take it to a professional.
    Concerned? Only you know how the car's maintained. Want something to do? Has the coolant been changed in the last 2/3 years? If not, do it now. Drain and fill with a 50/50% mix of DEX-COOL or all makes/all models coolant, and distilled water. NO ADDITIVES.
    When you have time, go to the black tab at the top of the page, and click on Cadillac Technical Archives. Read the ENTIRE page, LOTS of good info.
    Then read through the stickys here, and in the Northstar forum.
    68
    82,082
    Re: Pulsing Lights
    Nothing to add but
    Northstarnut likes this.
    Oct 2013
    Granite Falls, WA
    64
    20
    Re: Pulsing Lights
    Better to replace the alternator than rebuild it I assume at 64K miles?
    I have done a pile of GM cars so I think I can handle the brake/rotors on this!
    I did the dex/cool at 60000 so it is good
    To changeover to the trans VI fluid, I assume you have to drain and fill all including the torque converter? It sounds to me like a professional job.
    Thanks for the information and cites. I am a shade tree mechanic, but somewhere in the 90's the systems got away from me and I have neither the tools nor knowledge to tackle some projects. I bought the car with 37K miles and have had only a few minor things to fix since, but I want to start some preventive things so it won't surprise me when I can least afford to break down.
    Chuck
    Thank you!
    One more thing...is there a place to go to find trunk emblems? Mine is badly fading in the last year until there is almost no color. It was red
    Chuck
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,267
    Re: Pulsing Lights
    Brakes - remember: The rear caliper pistons screw back into the calipers - do NOT attempt to squash them with pliers or a clamp.
    Oct 2013
    Granite Falls, WA
    64
    20
    Re: Pulsing Lights
    I had a new alternator/voltage regulator put in to the tune of $500, and the lights are still flickering, now and with a battery that is only months old.Anyone else have a direction to go to get this flickering stopped? I am all for replacing defective parts, but replacing each component one at a time is probably not a great way to troubleshoot, but thanks to those with the advice! I would not have done it but for this forum, which I expected to be more knowledgeable about Cadillac than Bob the Mechanic. I was trying to avoid needless expense while they try to run it down. I guess someday I would have needed an new alternator and serpentine belt, right? Thanks guys! Anyone else want to chime in with a better guess?
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,488
    Re: Pulsing Lights
    brake pads will not cause - and will not cure a spongy pedal -
    a spongy pedal - TYPICALLY - is caused by air in the system -
    or possibly a master cylinder with an internal leak -
    what brand battery and alternator did you buy?
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: Pulsing Lights
    As long as we're throwing out ideas for the pulsing lights (common GM problem but mostly on other models and pickups):
    http://www.automotiveforums.com/t535...t_flicker.html
    You may have a grounding issue somewhere.
    Oct 2013
    Granite Falls, WA
    64
    20
    Re: Pulsing Lights
    what brand battery and alternator did you buy?[/QUOTE]
    NAPA and CarQuest respectively
  12. Remove Advertisements
