Error code rim b1327 on my STS 1998
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Error code rim b1327 on my STS 1998 in Past Cadillac Vehicle Discussion; I recently got error code rim b1327 on my Cadillac STS 1998, this means I got a "Vehicle system voltage ...
    aaberg is offline Cadillac Owners Member
    Automobile(s): STS 1998
    Oct 2011
    Karlskrona, Sweden
    53
    28
    I recently got error code rim b1327 on my Cadillac STS 1998, this means I got a "Vehicle system voltage below 9.0 volts". The problem appeared after the battery was drained and recharged (I have reset the OBD test several times but still got the error code). The battery is in good condition and I have recharged several days also tried another fresh battery just to be sure. Car display show the generator load is 14,2 volt and OK. No problem to start or drive the car, or any corrosion on cables etc, just this error message. Also have had the RIM removed and attached again, same problem. Any fuse that can be burned and set the code (the battery was recharged first time from + in engine compartment - not directly to the battery under back seat if this can give any trouble) or any other possible explanation?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    What is the voltage readout with the engine OFF? Preferably after being off for at least 30 minutes.
    Oct 2011
    Karlskrona, Sweden
    53
    28
    Re: Error code rim b1327 on my Cadillac STS 1998
    12 volt reading at the engine from hot + wire with the fuse box and - at the body. Last driven yesterday.
    Sep 2010
    East Boston MA.
    29
    26,323
    12.0?
    Oct 2011
    Karlskrona, Sweden
    53
    28
    Yes, 12.0 V
    69
    82,386
    12v is a little low
    Oct 2011
    Karlskrona, Sweden
    53
    28
    But the code is set at "Vehicle system voltage below 9.0 volts" and it´s far from that with 12,0 V. I have charged the battery before and got the code after that to.
    Sep 2010
    East Boston MA.
    29
    26,323
    The battery is at the end of its life. Under load, the voltage will dip lower than a healthy battery. Have it load tested, replace if necessary.
    Oct 2011
    Karlskrona, Sweden
    53
    28
    Re: Error code rim b1327 on my STS 1998
    Solved. Changed the module and it works. (yes, the battery isn't in best health, but didn't set the rim code).
  12. Remove Advertisements
