That coolant smell
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, That coolant smell in Past Cadillac Vehicle Discussion; Been a while, but I recently been smelling coolant in the cabin. Also I'm get a burning oil smell. Coolant ...
    caddyman769's Avatar
    caddyman769 is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ESC
    Aug 2011
    Washington DC Area
    10
    That coolant smell
    Been a while, but I recently been smelling coolant in the cabin. Also I'm get a burning oil smell. Coolant levels are going down very slowly (thinks its heater coil), same with oil levels. It's happening on a 02 Eldorado with 88k miles on it. One last thing, I replaced my rear lower controll arms bushing with polyurethane and now are squeaking more than the orginal rubber ones. What should I do? Thanks for the help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What should you do about???
    Inspect/replace heater core.
    Find oil leak.
    Replace bushings if you don't want to deal with the squeaking.
    68
    81,917
    Re: That Smell
    Heater core would be my guess as well.
    New bushings squeaking worse than the old ones? I suppose if you don't want to replace them you could try removing and greasing them with silicone and reinstalling them.
    Sep 2010
    East Boston MA.
    29
    26,325
    Poly bushings tend to squeal unless regularly greased.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 135K
    Oct 2010
    Pennsylvania
    446
    Re: That Smell
    I'm curious what was the part number of them bushings, just wondering because I have had no luck in finding bushings for the rear lower control arm
    Aug 2011
    Washington DC Area
    10
    I got them off a website called cadillacbushings.com thanks for the help. Car is in shop right now, will find out tomorrow what's wrong with it, but like you said, I postitive its the heater coil. Thanks again guys.
  9. Remove Advertisements
