1999 ETC bucking and surging at steady cruise speed
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 ETC bucking and surging at steady cruise speed in Past Cadillac Vehicle Discussion; At 65 mph and slightly noticable at a steady 45 mph my '99 ETC exhibits a surging in the engine. ...
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    At 65 mph and slightly noticable at a steady 45 mph my '99 ETC exhibits a surging in the engine. Feels like the gas pedal is being slowly pumped while cruising along.
    I put my foot into it hard...... it's fine.
    I have new plugs, new fuel filter, and new IAC.
    Has almost 125,000 miles
    Other than some pesky oil leaks it runs like a brand new Cadillac.
    I forgot to mention that the local Cadillac dealer replaced the fuel pressure regulator type thing about a month ago when I dropped it off to them. It displayed a sevice engine light and the dealer pulled some codes.
    The work they did knocked the service light out but it didn't get rid of the surge.
    68
    82,058
    Re: 1999 ETC bucking and surging at steady cruise speed
    HotRod, Did you post that in the wrong thread?
    OP, where you using the CC when this surging happens?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    Welcome Aboard !!!
    Study the proper year/model section of the sticky thread ^^^ "How to pull codes" from your car's built-in diagnostic code system.
    You may have a TPS (Throttle Position Sensor) fault, and that's a monitored sensor.
    Write down any codes found and return to the sticky to open the link to code definitions for your OBD-II system. Post all found codes and their descriptions here.
    I think he's posting under 2 usernames - and that will go away shortly ..........
    2manyhotrods, with 61 posts, will remain as the member username ................. The team sent him a PM, but no reply.
    The above post, "Welcome", was posted when his alter ego had only one post earlier today.
    68
    82,058
    Ahh, that splaines it.
    Jun 2013
    Massachusetts
    438
    Quote Originally Posted by Ranger
    No, I despise cruise contol, rarely use it. I'm too old fashion.
    Quote Originally Posted by Submariner409
    Welcome Aboard !!!
    Yes, 2 names was my fault. I'm on automotive enthusiast message boards and mixed them up a few weeks ago when logging into this one using another login.
    My screw up, very sorry.
    Quote Originally Posted by 2manyhotrods
    With the six message boards I'm on I have different logins and mixed them up good between the 2 Cadillac boards I use.
    Yes, my fault entirely.
    I feel like a dummy now!
    Feb 2006
    56,197
    Phooey !!!! No dummy - it's all in the learnin' ! (Now you know that if you post within XX minutes of another post in the same thread they automatically merge ................)
    Jun 2013
    Massachusetts
    438
    When I go ahead and install a TPS will I need to set it up with an ohm meter once installed?
    68
    82,058
    I think it does. Someone who remembers the procedure and setting will chime in.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No TPS setup for Northstars.
    Jun 2013
    Massachusetts
    438
    No setup? Well, guess that makes the job simple. I'll pick one up Monday or Tuesday and give it a whirl.
    Thanks!
  13. Remove Advertisements
