a/c recharge
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, a/c recharge in Past Cadillac Vehicle Discussion; So tomorrow I am probably going to recharge my ac. A friend of mine has the ac recharge machine, so ...
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    a/c recharge
    So tomorrow I am probably going to recharge my ac. A friend of mine has the ac recharge machine, so we will be using that.
    Is there a special procedure you need to do before or after the recharge? And how much 134 refrigerant will the system take if its completely empty? (98 eldorado)
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Not sure what the capacity is, but you need to find the leak first.
    ...And if your friend doesn't know how to charge an A/C system, he shouldn't be using the machine.
    68
    81,917
    Re: a/c recharge
    If the '98 is the same as the 2000+ it holds 2.2 lbs or refrigerant. You have to clear any low refrigerant codes to enable the compressor and draw a vacuum first, but if your friend has an expensive A/C machine I would assume he has a shop and knows how to use it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Re: a/c recharge
    I hope by "AC MACHINE" you are referring to a real recharging station -
    and you DON'T mean the mickeymouse single gauge can-tapper -
    if your system was/is low on freon there IS a leak somewhere -
    and that leak needs to be found/fixed -
    ignition ON - clear all codes -
    ignition OFF - evacuate the system -
    vacuum the system down to 29" for MINIMUM of 15 minutes -
    turn the vacuum pump off -
    verify the system maintains the 29" of vacuum for a MINIMUM of 15 minutes -
    with the engine OFF - start charging the freon -
    when one can - or one pound of freon is in the system -
    start the engine - turn the AC ON -
    set the temp to 60* -
    fan to medium speed -
    the compressor will cycle on and off as more freon enters the system -
    the cycling should stop after the second pound - full charge is 2.2 pounds -
    to verify proper AC operation -
    with the engine at a high idle - 1500-rpm -
    the air emitting from the center vent should be 37* to 42* -
    with an ambient temp of 85 or less -
    HIGH side pressure should be around 175 to 225 -
    LOW side pressure should be around 30 to 35 -
    Sep 2012
    Burbank, California
    740
    Yes he has the real a/c charging machine. I was asking this because I didn't know if Cadillac's ac system had a different procedure of recharging.
    Another question... does the system hold refrigerant after dropping the engine? Or do I have a leak???
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,368
    Re: a/c recharge
    Quote Originally Posted by eldorado_sean View Post
    there is no connection between the engine and the AC system -
    other than the engine spins the compressor -
    depending on HOW the engine was removed -
    would determine whether or not the AC system was opened or not -
    68
    81,917
    Re: a/c recharge
    It all depends on how it was done. The compressor COULD have been dismounted and left in place without opening the system, but I think most open it and remove the engine with the compressor still mounted.
  10. Remove Advertisements
