2000 SLS running rough
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 SLS running rough in Past Cadillac Vehicle Discussion; Ok so i just wanna start off by saying whats up everybody, Im new this this CADDY fourm page and ...
    Caddy 4 Life is offline Cadillac Owners Member
    Automobile(s): 2000 Seville, 2002 DHS, 1997 Eldorado, 1994 Eldorado
    Sep 2013
    Florida
    20
    Ok so i just wanna start off by saying whats up everybody, Im new this this CADDY fourm page and i look forward to a lot of help. So I have a 2000 CADILLAC SEVILLE SLS and it's running rough and shaking but sorta smoothes out when accelerated....
    *****NEW SPARK PLUGS
    *****NEW SPARK PLUG BOOTS
    *****NEW K&N AIR FILTER
    *****NEW BELT
    *****NEW OIL
    *****NEW OIL FILTER
    *****NEW FUEL FILTER
    *****NEW BOTH FRONT CONTROL ARMS
    *****NEW FRONT MOTOR/TRANSMISSION MOUNT
    XXXXX NOOOOOOOO VACCUME LEAK AT ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    XXXXX I SMELL UNBURNED FUEL
    AND STILL RUNS POURLY. Please help me soon
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Please don't start multiple threads on the same subject.
    Duplicate post:
    http://www.cadillacforums.com/forums...questions.html
    Edit: Never mind, it was closed.
    Have you checked for a sticking fuel injector?
    Leaking FPR?
    69
    82,393
    Re: 2000 Caddy seville SLS/STS RUNNING ROUGH
    Quote Originally Posted by Caddy 4 Life View Post
    Check for a leaky FPR.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    Re: 2000 SLS running rough
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Sep 2013
    Florida
    20
    FPR? what is that?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,169
    Just above this thread - in the stickys - the "Acronyms" thread. There are a ton of them you need to know because you'll see them time and time again in these forums.
    Sep 2013
    Florida
    20
    THESE R THE CODE THAT COME UP
    P0102
    p0412
    p0418
    p0419
    p0443
    What kind of leak?
    Feb 2006
    57,169
    As requested earlier, Please post your codes, definitions, and whether each is Current or History - Noboby has them all memorized - yet.
    FPR leak - Fuel Pressure Regulator - gasoline.
    This is a generic FPR - a ruptured diaphragm will leak raw gas out the vacuum nipple - yours is on the side of the dome.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    looks like a bad MAF sensor -
    Sep 2013
    Florida
    20
    not it i had changed
    Sep 2013
    Florida
    20
    Ok so all these code turned out to be a bad fuse. Now i have a p0300 which is cylinder/ cylinders misfire. Dont wast my time. New Plugs, New boots, NO VAC LEAKS, fpv is good. i smell gas out the exhaust and smooths out at 2000 + rpm
    Feb 2006
    57,169
    Not that I want to "wast (your) time", but you might want to find the cause of the P 0443 DTC. Then bounce that against your remark about "NO VAC LEAKS".
    Fuel smell in the exhaust at low speeds might be a leaky fuel injector.
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    ya - certainly wouldn't want to wast YOUR time - but -
    P0300 is a generic misfire code -
    our on-board code readers will not display WHICH cylinder/cylinders is/are misfiring -
    only that there IS a misfire -
    take the car to any large auto parts store - they will check your codes for free -
    P0301 is a misfire in cylinder #1 - P0302 is cylinder #2 - P0303 is #3 - etc -
    once you discover WHICH cylinder is misfiring - diagnosis becomes much easier -
  16. #14
    Sep 2013
    Florida
    20
    ok the ONLY CODE comming up is P0300. I have NO!!!!!!!!!!!!!!! vac leak
    sarcasim not needed but thanks.
  17. #15
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,867
    spellcheck is your friend -
    you get what you give -
    oh - there is no "I" in sarcasm - you are welcome -
  18. Remove Advertisements
