2000 Eldorado...Service Stability System/Traction Control/Antilock Warning Messages
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 Eldorado...Service Stability System/Traction Control/Antilock Warning Messages in Past Cadillac Vehicle Discussion; Hi...looking for a little help here. I have a 2000 Eldorado ETC. About 3 weeks ago, the car was giving ...
    sjc313epd is offline Cadillac Owners Member
    Automobile(s): 2000 Eldorado ETC, 2010 DTS Platinum
    Mar 2009
    Central NJ
    50
    44
    I have a 2000 Eldorado ETC. About 3 weeks ago, the car was giving me warning messages being "Service Stability System/Traction Control/Antilock" with a current code at that time being C1235 - "RR Wheel Speed Sensor Open Or Shorted"
    After following the advice on this fourm, I ordered an OEM AC DELCO hub/sensor, along with new rotors/pads/tires and had my mechanic replace all of the parts on Saturday 9-21-13.
    When I picked the car up, he said that no codes were active and that all warning messages went off.
    As I drove home....the "Service Stability System/Traction Control/Antilock" Warning Messages went off yet again.
    I called him and he said he test drove the car for 10 miles and no warning messages went off.
    I shut the car off and no mesages came on upon restarting the car...but when I ran a self code test, it showed no current codes but the history now shows C1234 ""LR Wheel Speed Sensor Open Or Shorted" along with C1235 (which I expected to see)
    The weird thing is that I checked those codes at least 20 times in the last 3 weeks, and not once did the C1234 code appear.
    My question now is.....does the C1234 code have anything to do with this, or can it be some kind of short in the wiring going to the sensor on the hub.
    I appreciate anyone's help in this.
    Thank you......Sal
    68
    81,928
    Re: 2000 Eldorado...Service Stability System/Traction Control/Antilock Warning Messag
    It IS possible that it could be a wiring or connector problem.
    Mar 2009
    Central NJ
    50
    44
    Thank you very much
