Results 1 to 5 of 5
Thread: turn signal switch 99 Eldorado
    basic_390 is offline Cadillac Owners Member
    Automobile(s): 99 eldorado
    Sep 2012
    26
    26
    when I first bought the car a year ago the problem I had was when I would press the brakes for a extended period of time (sometimes not all the time) I would get a Lil bit of smoke from behind the steering wheel (mostly and drive thru windows and long stop lights).So one day after it smoke REALLY bad I notice that to brake lights wouldn't work anymore. I replaced all the the bulbs and they still didn't work but everything else did like turn, 3rd bk light, tail-lights, and hazard.so after doing some research I found out about to turn signal switch and replaced it .the first time I couldn't figure out how to get the connector down the column so I cut it an spliced.the brake light were working now but the rear brake light would sometime come on blinking like hazards even when I cut the car off. so I replaced it again without cutting it and now when I hit the turn signal both LF,RT sides flash together and I can't tell if its hazard of both turn signal going at the same time. I just don't understand what I could be doing wrong could there be a bad ground somewhere
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    Re: turn signal switch 99 Eldorado
    Sounds like you hacked the wiring and that is where to start. Just as a side note why would you let something smoke inside the car and then why did you change the bulbs when something was frying inside the dash?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,694
    if you are going to try to fix this yourself -
    you are going to need the wiring diagrams -
    the Factory Service Manual -
    or an on-line subscription to AllData - will have them -
    good luck - and keep us posted -
  5. #4
    Sep 2012
    26
    26
    I let it smoke because It did it every blue moon I didn't have the money to take it to the dealer and changed all the bulbs because the brake lights weren't working and I had an inspection coming up
    Quote Originally Posted by rodnok01 View Post
  6. #5
    4camjewelry is offline Cadillac Owners Member
    Automobile(s): '98 Eldorado, '99 Deville, 4.9 Fiero, N* Fiero project
    Sep 2010
    near Indy
    1
    basic, it's simple enough to find whether it's the TS or the hazard circuit that's running. Think about it, TS is powered only with IGN ON, hazard is HOT ALL TIMES. They're absolutely separate circuits until they reach the TS switch, so if you're not convinced by the IGN on/off test, you can pull either fuse to confirm which is powering: your TS is underhood fuse "TURN" and the hazard is rear compartment fuse "HAZARD." Seems to me if you put an good intact harness back in, you're still dealing with a messed-up switch; the little actuator cams and links all have to be indexed and set in there just right. I'd go to the boneyard and pull another one open to reverse engineer it.
    basscatt is right, it'll be much less painful with some good documentation. There used to be real GM Electronic Service Information GMSPO discs around for cheap, like $30 on ebay, listed for specific vehicles. Got one for my '99 Deville and was blown away when I discovered it has everything GM from 1980-2005. Sadly I don't see them on there right now. I looked at the switch replacement section for your '99 Eldo and it seems pretty straightforward w/ no real tricky stuff.
    Best luck!!
  • You may not post replies
