nav disc
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, nav disc in Past Cadillac Vehicle Discussion; Moderator edit: Do not even consider discussing pirated software in CF. Thanks, CF Staff....
    stoneface1959 is offline Cadillac Owners Member
    Automobile(s): 2002 seville sts 114000 mi
    Oct 2010
    Kenmore NY
    57
    15
    nav disc
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,365
    Re: nav disc
    Quote Originally Posted by stoneface1959 View Post
    Looking for a copy of nav software disc for 2002 seville. Could this be why system will not turn off?, battery runs down overnight
    Thanks for any help
    Joe
    NO -
    sounds like you have a RAP problem -
    if you turn the ignition off -
    the accessories should continue to function for up to 10 minutes -
    or until the door is opened -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Oct 2010
    Kenmore NY
    57
    15
    Re: nav disc
    ok the nav system says I need a disc. I have 2 codes amp u1000 class 2 serial data circuit and rss c0662 auto level control, there were some history codes also. But my day just got worse the car will not start and it rain a lot last night and now the passenger side rear floor is a lake. I read up on the water issue and I don't have a sun roof so maybe the door seal.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Re: nav disc
    I believe the nav disc must be in at all times to work -
    "U" codes are loss of data/communications codes -
    they come and go quite frequently - and for the most part - can be ignored -
    that is an exhaust valve/solenoid problem -
    is the rear sitting at the correct ride height?
    does the compressor activate with an additional load in the trunk -
    does the exhaust solenoid open to release the extra air pressure -
    when the trunk load is eliminated -
    history codes are important too -
    HISTORY means there was a problem -
    but the problem is not happening RIGHT AT THIS MOMENT -
    you should post them too - ALONG WITH THEIR DEFINITIONS -
    check the trunk - spare tire well -
    the trunk seal is a known problem -
  7. Remove Advertisements
