Results 1 to 10 of 10
Thread: P 0300 Random/ multiple misfire detected - STS 97
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    First my exhaust was broken for awhile and I still drove the car, about 3 months. I recently had a shop weld it up and it sounds great. Ever since the motor has been running rough, this has been going on for two weeks now and the first code just popped the po300. It seems that the misfire is when the car is first started but then goes away after a few miles, then only returns after siting for awhile. The plugs and wires have about 50k on them. Not sure if I should start there or what.
    Some more info is that I had a EGR recirculating flow low code set before the exhaust break, then it went away while the exhaust was broke, now the exhaust is fixed and no EGR code, but now the engine is running rough now with the p0300 code.
    Mass flow, plugs wires, catalytic converter, TB????????
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Check the coils!
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,800
    Re: P 0300 Random/ multiple misfire detected - STS 97
    Plugs, wires, coils, ICM base contacts, ICM ground wire.
    Use this to make sure the plug wires are correctly connected to the coils and plugs.
  5. #4
    69
    82,262
    When was the TB last cleaned?
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,675
    P0300 is a generic misfire code -
    our on-board code readers will not display WHICH cylinder/cylinders is/are misfiring -
    only that there IS a misfire -
    take the car to any large auto parts store - they will check your codes for free -
    P0301 is a misfire in cylinder #1 - P0302 is cylinder #2 - P0303 is #3 - etc -
    once you discover WHICH cylinder is misfiring - diagnosis becomes much easier -
  7. #6
    Jun 2010
    Rochelle IL
    302
    Quote Originally Posted by Ranger
    I cleaned it about 20k miles ago maybe more. I put 93 octane in it to flush out any bad gas that may be in it. The car misfires on the cold first start after that it runs fine.
  8. #7
    69
    82,262
    What makes you think you had "bad gas"?
    Hmm, are you by any chance using coolant?
  9. #8
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by zek4964 View Post
    ....It seems that the misfire is when the car is first started but then goes away after a few miles, then only returns after siting for awhile. The plugs and wires have about 50k on them. Not sure if I should start there or what.
    A misfire at cold start can be one of the early symptoms of bad news.
    Are you having to add coolant to the system?
  10. #9
    Jun 2010
    Rochelle IL
    302
    I have not added coolant since I replaced the surge tank. I have been driving it to work and the temp gauge has not been above midway point since the surge tank change.
    What bad news are you talking about head gasket? I really hope not it will be a dead car because I will not fix it.
  11. #10
    69
    82,262
    Yes, that's one of the early HG symptoms, but since you have not added coolant and the temp gauge has not moved I think you are OK.
  • You may not post replies
